compression
I have calculated the compression ratio on my 1680cc twincam using Dave Bean's formula.
CR = SV + CV divided by CV
where: SV = swept volume
CV = clearance volume
and where: CV = HV + PV + GV + DV + LV
GV above is the volume of the head gasket
When using a .060" gasket, the compression ratio is 10.4 to 1
When using a .030" gasket, the compression ratio is 11.45 to 1
I didn't think head gasket thickness had such a large affect on CR but I recalculated and got the same results.![Question :?:](https://lotuselan.net/forums/images/smilies/icon_question.gif)
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
Are those the measurements for the CH gaskets in use i.e compressed thickness and using it’s actual fire ring diameter, not the bore dimension?
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
I used those gasket thickness dimensions only as a rough guide to see how they affect the compression ratio. I actually plan to use a cometic CFM gasket which will compress to about .059".
I am surprised how much a .030" difference in thickness affects the CR. That is, if my math is correct.![Smile :)](https://lotuselan.net/forums/images/smilies/icon_smile.gif)
67 Elan +2
67 Elan +2
- seniorchristo
It does make quite a bit of difference the thickness of the head gasket.. What is LV in the formula?
I assume:
CV = compressed volume
HV = head chamber volume
PV = piston valve pocket volume
GV = head gasket volume
DV = dead volume (volume to head face at TDC excluding gasket)
LV???
I assume:
LV???
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
LV is headland value. That little bit of space below the piston top down to the top ring ![Smile :)](https://lotuselan.net/forums/images/smilies/icon_smile.gif)
On my engine it figures to .3 cc.
67 Elan +2
67 Elan +2
- seniorchristo
