Head to block breather tube replacement
Gents,
I have just had my cylinder head ( Weber) worked on, new cams, seats, guides, followers and slight skim.
But unfortunately never replaced the old breather tube with new and of course it is leaking pretty badly.
The head gasket is absolutely sound. So I would not want to take head off again.
Can anyone please tell me if the breather tube can be replaced with head in situ, I have been told you can bend on middle and remove or refit.
Any advice is welcome.
Jason
Jason
- JasonJ
Allegedly yes. Place in hot water to make it really supple prior to fitting. You may as well try it as if it doesn’t work you are no worse off.
'72 Sprint
'72 Sprint
- richardcox_lotus
I used a VW pushrod adjustable tube replacement. You have to cut it down to fit, but otherwise it's a perfect fit. Here is an example https://www.jbugs.com/product/9139.html?rrec=true
Fred Talmadge - Fourth Gear
Hi Fred
Nice, did you shorten it from the blue part nearest the 2 locking nuts? And roughly how much did you have to take off, I presume the blue sleeve is threaded enough internally?or is there a seal in there , and were both ends a good fit with seals, did you use the ones provided?
I like this idea.
Jason
I like this idea.
Jason
- JasonJ
People have come up with various versions that can be installed with the head in place.
viewtopic.php?f=50&t=52608
https://www.youtube.com/watch?v=iCr1traZlMg
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
steve lyle - Third Gear
Jason, is was decades ago and didn't write anything down. The yellow inside part is threaded all the way, it just slips inside the blue part and you use the jam nuts to adjust the length and tighten it so it doesn't leak. I just eye balled it the length. It's pretty forgiving.
richardcox_lotus wrote:Allegedly yes. Place in hot water to make it really supple prior to fitting. You may as well try it as if it doesn’t work you are no worse off.
I have successfully done this. Bit of a pain of a job but do able, get it hot and then squeeze it in the middle. Which let's you fold/bend it slightly, fit the bottom end in and then push it under and in to the top hole.
Probably wise to cut a bevel on the ends just to help it slot in.
- mbell
Fred Talmadge wrote:I used a VW pushrod adjustable tube replacement. You have to cut it down to fit, but otherwise it's a perfect fit. Here is an example https://www.jbugs.com/product/9139.html?rrec=true
This looks like a good solution. I would use some RTV or "O" rings with it though.
Berni
berni29 - Fourth Gear
