Rad brackets
HELP ! Not sure if I should be in body department but I’ve got my radiator brackets out of hibernation and looked at body and rad and can’t figure it out I have a s3 rad to go inI place of s4 small rad so gather it’s the same fittings but were do they go any pics will help kind regard. Len
- Lens4
Hi Len,
This is how my S4 (narrow rad) brackets are fitted .. larger, offset angle bracket goes at the top, bolted to the bonnet hinge platform stay and the smaller, plain right angle bracket goes at the bottom, bolted directly to the fibreglass. The upper set of holes on the radiator side plates are used so the radiator is mounted as low as possible in the car.
S4 DHC
S4 DHC
- oldelanman
