Mystery Bolts.
PostPost by: dlb123 » Wed Jan 24, 2024 11:04 am
Hi there. Hoping someone may be kind enough to help me. In my box of engine bits I've found four unidentified bolts. I assumed they were for a pulley or something of that nature but it would appear not.
I've included photo with pitch and length.
Thanks a lot for any suggestions!
PXL_20231013_143623736.jpg and
dlb123
First Gear
First Gear
PostPost by: billwill » Wed Jan 24, 2024 11:29 am
Going by memory which is rather fallible, they might be the bolts which fasten the water pump pulley to the waterpump Boss.
PostPost by: promotor » Wed Jan 24, 2024 1:40 pm
They look like fine threads - the only fine threads I can think of in the LTC are the con rod bolts and the three through-bolts and nuts for the water pump front to back covers - they're definitely not any of those bolts!
Water pump pulley to flange are supposed to be 1/4" UNC.
They're known as "worry-bolts" - they're only in the box to worry you, they serve no other purpose!! :lol:
promotor
PostPost by: dlb123 » Wed Jan 24, 2024 1:54 pm
Haha thanks a lot for the responses. I finally figured out they're from the gearbox mounting to chassis. I was somewhat reassured by the fact they had some muck / corrosion on them, and therfore assumed it was they would be external. Phew!
Thanks again.
David
dlb123
First Gear
First Gear
Users browsing this forum: No registered users and 47 guests
