engine losing power
Car recently legally allowed on roads so went for a spin, as part of process engine was rebuild and carbs tuned etc.
On highway going up hill car lost power, requiring change down to get revs up to carry on, did this a couple of time on flat when reaching around 50mph.
My thoughts are,
1. lack of fuel, not enough pressure or supply
2. Blocked silencer restricting exhaust fumes ( the reason is that I could clearly hear something lose in silencer when rebuilding car).
Any thoughts on what to check, how do you test/clean exhaust silencer?
My thoughts are,
- street
most silencers are rebuildable, new material and some welding
checking fuel pressure is easier, and better to start with the basics. distributor advance, or heating up component?
Love your Mother
Earth
Love your Mother
Earth
Fuel starvation from your description is certainly a possibility. Don’t neglect the simple things though eg. ensuring that you have full throttle travel of the cable happening at the carbs. Always difficult to do these types of diagnoses by remote control.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
The first clue was that once I was safely off the road and took a look at the engine, I saw fuel leaking from the front bowl's vent. That told me that too much fuel was being admitted to the bowl, meaning the valve was probably either staying open or opening too much. I opened both bowls, removed the floats and with just weighing the floats in the palm of my hand, could tell that the one in question was much heavier than the other. I allowed it to drain and gave it a good shake just to be sure, then as I was only about two miles from home was able to drive back before it loaded-up again. A new set of floats got installed and it runs fantastically now.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
The other trick to identify a leaking float is to put it in boiling water. Where you see bubbles is where the leak is.
- 2cams70
Re-Leaking float.
I wonder if ethanol was to blame?
Was this a plastic float or brass float? Other classic car marques have recently been noticing the the effects of ethanol on plastic floats that were specifically not made of ethanol proof plastic material.
Ethanol will also I understand over a period of time attack the solder used in the manufacture of the traditional brass carburettor floats.
Alan.
Alan.
'71 +2 S130/ 5speed Type9.
- alanr
alanr wrote:Re-Leaking float.
Plastic, purchased seven or eight years ago, I forget from which usual suspect but one of the ones in the USA. The new replacements were described as ethanol-resistant and I did notice that they looked a little different. Got fingers crossed for the resistance to be durable.
2012 BMW R1200GS
2012 BMW R1200GS
Street
Most retro fit electronic ignition kits use the distributor springs and weights on Lucas distributors.
So you need to check what type is fitted
Although I suspect you have a fuel problem.
Good luck and please report your final fix
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
