Winter lay-up
Just pondering the best procedure for protecting an engine if it were laid up over winter.
I understand that it should be with fresh oil so that should be changed but once done should I run the engine to let it circulate, or just fill and leave? Running it by just idling is unlikely to get it hot enough to burn off crankcase moisture so I've heard and driving it isn't an option at the moment. But then just filling it and leaving would presumably leave the old dirty oil on the bearing surfaces/seals etc and be the same as not changing the oil at all?
Opinions please?
Robbie
Opinions please?
Robbie
Give "fogging oil" a search on Google/YouTube
1967 S3 FHC
1968 S4 FHC
1967 S3 FHC
1968 S4 FHC
- smo17003
Gas tank should be full to prevent corrosion and oxidation, plus add a stabilizer.
Run the engine for a few minutes after the oil change. The tiny amount of moisture will quickly be absorbed by the detergent/dispersant additives in the oil. Fogging oil is good to coat the intake, combustion chambers and upper cylinder walls. The fogging oils have a corrosion inhibitor. At idle, spray the fogging oil until the engine dies. Switch off the ignition. Suggest removing the battery from the car and putting it on a tender.
Pray for Spring.
Pray for Spring.
smo17003 wrote:Give "fogging oil" a search on Google/YouTube
Never thought about fogging oil for a car. Its very common in the marine world where the boat gets winterised and the environment is generally wet. Moist air gets into the engine and into the cylinders that have open valves corroding the valves and cylinder walls. On engines with water injection cooling of the exhaust, there is always water hanging around in the exhaust pipes and damp air in the exhaust manifold.
We don't have that problem on the Elan, but it seems like a good idea to protect the engine from an extended period of no use.
A float charger for the battery is also good idea, there are specific 'maintenance' chargers for this purpose. Don't just use any old charger you found in the back of the garage.
Andy.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Completely loosen off the fan belt. Turn the water pump by hand every few weeks so that the seal doesn't get stuck.
I also pump the clutch and brakes to keep them moving.
Nick
Nick
elanner - Fourth Gear
Thanks everyone,
Great tips - very helpful
Robbie
Robbie
Andy,
Are you saying that the old charger I found in my dad’s garage after he died could damage my new battery?
Richard Hawkins
Richard Hawkins
- RichardHawkins
