Chain tensioner plunger in front cover
It is a while since I dismantled my engine, and I didn't have any luck finding an answer to this via the search function.
Should it be possible to insert the tensioner plunger from the outside of the timing case, i.e. past the threaded section?
The original plunger I have won't fit in the new removable water pump front housing and I wondered if the hole should be reamed from the outside, hence the question. I found a reference to fettling it to fit, but no detail, if anyone has done it before and has any tips? Thanks.
- ill_will
ill_will wrote:It is a while since I dismantled my engine, and I didn't have any luck finding an answer to this via the search function.
It is possible with a genuine Lotus waterpump casing but the reproduction standard covers don't let you in my experience - they usually only fit in from the other end so some fettling of the thread itself is required but not the plain part of the bore. I would guess it's probably the same for the removable module covers as it's likely they are coming from the same factory.
promotor - Fourth Gear
Measured up some orginal covers and a new Dave Bean cover and got pretty consistent measurments across them all. The threaded section of the plunger hole is 13.4 mm diameter. The plain section of the hole 13.3 mm.
I just finshed building an engine with a Burton front cover I had purchased a few years ago and the plunger went in OK from the outside also.
I recently put a new tensioner from QED into a Burton front cover and it went in just fine from the outside.
- pianoderby
The new plunger from QED arrived and measures approx 13.35 mm (verniers.) This was a snug fit in the Burton front cover from the inside, and needed some slight rework to get it to rotate without jamming. It won't pass the threaded section from the outside.
The original piston I had was about 0.1 mm larger, so it may be custom made and the hole in the original front cover enlarged slightly. Thanks all for the comments.
- ill_will
