Adjustable Cam Sprockets
What is the consensus on the use of an alloy or a steel centre boss on adjustable cam sprockets?
Both are available from the usual suppliers, is there an advantage/disadvantage to the use of either?
Colin would have picked the alloy
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
Hawksfield wrote:Hi
Colin would have picked the alloy john
You could be right there
If you are dialing in your camshaft then your choices are to machine offset keys or use an adjustable sprocket. If you are just going to "line up the dots" then it's an extra expense for nothing.
Fred Talmadge - Fourth Gear
Fred Talmadge wrote:If you are dialing in your camshaft then your choices are to machine offset keys or use an adjustable sprocket. If you are just going to "line up the dots" then it's an extra expense for nothing.
Fred, I think the OP is asking about the merit of aluminium v steel construction of the adjustable timing sprockets rather than their value over other methods of setting the valve timing.
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Fred, Malcolm is correct, I’m fully aware of the off-set dowels and have used them many times, I was inquiring about the pro’s & cons of using one type of adjustable sprocket versus the other.
