Thermostat Housing
Also good for bleeding air out of the system...highest point.
John![Wink ;-)](https://lotuselan.net/forums/images/smilies/icon_wink.gif)
It's a standard Ford part.
Oddly enough it isn't the highest point, I have that on my system & the coolant in the thermostat housing has just about the same clearance as the coolant under the radiator cap.
![Image](https://lotuselan.net/lel/23170/1/FanSwitch.jpg)
viewtopic.php?t=26627&p=176812
Sorry but,
Personal choice i prefer the Otter Switch in the Rad lower down so always surrounded by coolant. Switching on Fan when Rad is at cut-in temp.
- alan.barker
I stand corrected....
Also good for bleeding air out of the system...joint highest point.
alan.barker wrote:Sorry but,
This setup also moves the expansion tank take off to the new filter neck. You can see the reinforced hose in the picture. So the fan switch is surrounded by coolant if the system is correctly filled/bleed.
Of course it does mean you need to do something with the filler neck on the radiator. I had mine blanked off but could just filter a higher pressure cap.
- mbell
Users browsing this forum: rgh0 and 20 guests
