Starter motor tooth number
Thanks for your comments.
I found my problem.... I swapped an early 10 tooth starter motor for a second hand 10 tooth Powerlite one made also for Ford bellhousing BUT :
- Early one had 10 tooth with 29mm external diameter and 21 between tooth
- New one was also 10 tooth but 27mm external and 18 internal
.... worked but with an anti mechanical noise: So check both tooth number but also pinion diameter !
- huggy59
