Lotus Elan
Calculate compression ratio from compression tester result
PostPost by: JonB » Wed Sep 27, 2023 3:49 pm
Bit of a technical one, this.. Can the Twink's compression ratio be worked out (even approximately) from the readings taken from a compression tester?
For example, I measured 192, 196, 199, 210 PSI respectively in a cold crank test (albeit with the throttle closed) for cylinders 1,2,3,4 respectively. Is there a formula for calculating the compression ratio from these?
Ta muchly
PostPost by: promotor » Wed Sep 27, 2023 7:43 pm
I'd say it would be hard to get an accurate compression ratio figure - different cams will give different readings, cam timing and even small things like how loose or tight cam/valve clearance figures are will make a difference. Piston ring sealing will also vary results so it would be an educated guess.
promotor
PostPost by: john.p.clegg » Wed Sep 27, 2023 8:55 pm
PostPost by: JonB » Thu Sep 28, 2023 9:08 am
Thanks John, very useful. I'm figuring something like 10.5:1 ratio but I will do another test once the engine is running.. in about 100 years at this rate...
PostPost by: Donels » Thu Sep 28, 2023 5:06 pm
That's a cracking document. Very interesting.
Elan +2
Elise mk 1
PostPost by: Spyder fan » Thu Sep 28, 2023 5:53 pm
If I remember correctly the standard compression ratio for a lotus twin cam of your cars vintage is 9.5:1
No doubt those with more definite knowledge will be along shortly. 10.5:1 would be a modified/uprated engine
Kindest regards
Alan Thomas
Spyder fan
PostPost by: JonB » Fri Sep 29, 2023 8:07 am
Interesting, Alan. It's an S/E engine with a D cam. I've seen these engines referred to as "Super S/E".
