Can anyone tell me what this is?
PostPost by: dlb123 » Tue Aug 29, 2023 9:38 am
Hi there. Slight dunce question here but I've reassembled the clutch and flywheel back onto the engine. However when i was reviewing the illustrations from the manual I noticed a part that I was not familiar with.
I'm picking this project up after a long hiatus and just wanted to double check I've not missed anything.
Have highlighted in the photo!
Thanks for any help you might be able to give me :-)
Screenshot_20230829-103423.png and
dlb123
First Gear
First Gear
PostPost by: rgh0 » Tue Aug 29, 2023 9:54 am
Hard to tell exactly with the data presented but it appears to be the insert that fits in the flywheel for the pilot bearing to fit into for the Lotus 5 speed ? Not used in the 4 speed as the pilot bearing fits into the crank shaft itself.
PostPost by: oldelanman » Tue Aug 29, 2023 10:10 am
It's the spigot bearing according to the parts list......
Screenshot 2023-08-29 110248.png and
Screenshot 2023-08-29 110311.png and
S4 DHC
PostPost by: rgh0 » Tue Aug 29, 2023 10:32 am
So if its for an early Elan that is an other option. So what type of car is it for if I may ask ?
PostPost by: Craven » Tue Aug 29, 2023 11:19 am
Spigot bearing for 4 bolt crank, usually sintered bronze takes larger diameter gearbox input shaft.
