Capillary tube fitting leak
PostPost by: gjz30075 » Tue May 09, 2023 11:00 am
I have a leak where the capillary tube goes into the adapter in the head. I'm pretty sure it's not the
adapter. When first assembled a few years ago, it was a freshly 'rebuilt' gauge from Mo-ma and
there was no leak. Gauge failed recently so back to Mo-ma it went. I now have a leak at this
fitting location and I'm reading that there should be a gasket on the bulb, where it meets the
adapter (adapter has a gasket where it meets the head). Moma says no gasket it needed.
If there should be a gasket, it looks to be pretty unique with a large i.d. to a not much larger o.d.
So, should there be a gasket at the location in the picture?
DSC01547.JPG and
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: types26/36 » Tue May 09, 2023 11:03 am
If I remember correctly there should be a small copper washer on that location.
types26/36
PostPost by: rgh0 » Tue May 09, 2023 11:06 am
I believe the original design was no gasket and just a compression fit between the aluminium adapter and brass sensor bulb.
If using a steel or brass adapter or a badly corroded aluminium one you may fail to seal without some form of gasket or sealant. I have used teflon tape on the bulb flange in the past. A soft copper washer or fibre washer may also work.
PostPost by: gjz30075 » Tue May 09, 2023 11:07 am
Thanks Brian. I'll start calling our Lotus vendors to see if they have one.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: gjz30075 » Tue May 09, 2023 11:10 am
Rohan, it's possible my adapter is 'borderline' , going from 'no leak' to now leaking. I'll lightly
dress the mating surface and hopefully it'll make a difference. I'll continue to look for gasket/washer,
or use teflon tape.
Thanks.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: types26/36 » Tue May 09, 2023 11:32 am
Greg, just checked my spare gauge and it has a copper washer.
1.jpg and
2.jpg and
3.jpg and
types26/36
PostPost by: gjz30075 » Tue May 09, 2023 11:46 am
Thanks Brian!
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: pharriso » Tue May 09, 2023 1:03 pm
Yes, there should be a small copper seal, needs to be soft (ductile) to seal...
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: gjz30075 » Tue May 09, 2023 2:03 pm
Just sourced a couple from RD Enterprises so it must be a real thing.
Thanks.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: pharriso » Tue May 09, 2023 2:07 pm
gjz30075 wrote:Just sourced a couple from RD Enterprises so it must be a real thing.
Thanks.
Or an empty envelope...
Phil Harrison
PostPost by: RichardHawkins » Tue May 09, 2023 6:35 pm
Excuse me if I hijack this post, as I am currently working on this general topic of temperature measurement.
I have two gauges, I don’t remember how or why. Both are reasonably correct at 80C, one has a grommet for sealing where it passes through the bulkhead, but the temperature indicating needle is loose and tends to fall off, the other has no grommet, but the needle is secure. Does anyone know if a grommet can be fitted without cutting the capillary or the grommet, or how to secure the needle?
Richard Hawkins
RichardHawkins
PostPost by: gjz30075 » Tue May 09, 2023 7:10 pm
You might be able to fit the grommet over the brass nut but I've always simply slit the grommet to fit on
the capillary tube
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: pharriso » Tue May 09, 2023 9:03 pm
I've rebuilt / recharged a number of these dual gauges & sensors...
RichardHawkins wrote:the other has no grommet...... Does anyone know if a grommet can be fitted without cutting the capillary or the grommet....
Richard Hawkins
You can slit the grommet so the nut passes through, then use Superglue
RichardHawkins wrote:.... but the temperature indicating needle is loose and tends to fall off.....or how to secure the needle?
Richard Hawkins
Twist the chrome bezel off the gauge, remove glass & seal... heat the sensor to 212 deg F in a saucepan of boiling water & replace the needle with a dot of superglue with the needle at the indicated temperature. It should be a push fit without, but the superglue will may sure the needle stays put.
Phil Harrison
PostPost by: Craven » Tue May 09, 2023 10:13 pm
It’s a very small taper fit, very very light tap will do it.
PostPost by: RichardHawkins » Wed May 10, 2023 6:37 pm
Thanks for the suggestions. My travels today took me past Nottingham, so I called at Speedograph Richfield, there I was assured of what I already expected that the grommet won’t pass over the nut. Speedograph secured the needle for me while I waited and supplied a new bezel, which I thought was good value at £10 all in.
Richard Hawkins
RichardHawkins
Next
Users browsing this forum: No registered users and 51 guests
cron
