1500 Engine?????
PostPost by: nomad » Sun Apr 30, 2023 5:02 pm
Seems I read somewhere that Lotus replaced all the 1500 engines in Elans with 1600 engines. Is my memory playing tricks on me?
I've been relaying this and may be a liar. Experts???
Kurt
nomad
PostPost by: types26/36 » Sun Apr 30, 2023 5:56 pm
From the now defunct Type 26 Register.
1500 cars.JPG and
types26/36
PostPost by: nomad » Sun Apr 30, 2023 9:00 pm
Thanks, I miss that spot.....
Kurt
nomad
PostPost by: bitsobrits » Mon May 01, 2023 2:31 am
Same basic block for both, IIRC.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PostPost by: h20hamelan » Mon May 01, 2023 6:12 am
& a 1700 is taller?
Love your Mother
Earth
PostPost by: nmauduit » Mon May 01, 2023 8:40 am
h20hamelan wrote:& a 1700 is taller?
the well known article sumarizes the most common situations
http://www.lotus-cortina.com/library/block/blocks.htm
in first approximation "1500" blocks are of original Lotus dimensions (bored to 1600cc for later models), while "1600" blocks (crossflow etc.) are taller by about 0.4" (when overbored can offer 1700cc)
S4SE 36/8198
PostPost by: 2cams70 » Mon May 01, 2023 10:04 am
That often quoted Lotus Cortina link about Ford blocks is somewhat right but it’s also somewhat wrong too!
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: rgh0 » Mon May 01, 2023 10:10 am
The blocks used in the first few very early Elans were the 5 bearing 116E blocks introduced in 1962. 1500 cc with 81.0mm standard bores. Replaced with the same block with 82.55 mm bore to make 1557cc and the Elan 1600.
PostPost by: nomad » Mon May 01, 2023 12:16 pm
Thanks guys. I would not imagine Chapman replacing the 1500 engines if it were going to cost him real money! :D
The 1500's were likely just traded to the machinist or Ford or where ever he sourced the engines. Would have been out very little and probably gained good will.
Kurt
nomad
PostPost by: trw99 » Mon May 01, 2023 2:06 pm
Although Tim Mees says 8 1500 Elans had their engines replaced, 2 of the development Elans also had the 1500 engine when they were first sold on.
3 early Elans also had engines with both a Lotus Engine No as well as a Cosworth Engine No. These cars were bought by club racers, as indeed were many of the very earliest Elans.
Of passing interests is that the good looking Frua Elan was also fitted with one of the 1500 engines, though of course it was more for show than go!
PostPost by: nomad » Tue May 02, 2023 5:39 pm
Thanks, Tim.
Kurt
26/3754
nomad
