Engine fan??
I used the 8 blade yellow plastic fan from a Cortina for years. It needs to be spaced within about an inch of the radiator core. Only marginally more effective than the steel bladed fan.
Hi Kurt,
Imho it would be better to remove and fit a Kenlow Fan with variable thermostatic control. When stopped in traffic it helps cooling much better.
- alan.barker
512BB wrote:You would have to be sure that any replacement blades that you bought were compatible with the size of the motors shaft. The earlier motor had a thinner shaft.
Leslie
Leslie the op is talking about a fan blade on the water pump…
I’d recommend removing any mechanical fan as it is a load on the water pump bearing & going with an electrical fan forward of the radiator a La S3/S4 & Sprint.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
The sun probably gets dazzled by the shine on that motor, David.
I thought you lot didn’t like bulling yer boots!
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
Yes, an electric really makes the most sense. I've fitted them to other cars and was just looking at something temporary on this one. Water pump bearings are already loose and I don't think that a, heavy, likely out of balance, steel fan is doing them any good.
Kurt
Kurt
- nomad
nomad wrote:Yes, an electric really makes the most sense. I've fitted them to other cars and was just looking at something temporary on this one. Water pump bearings are already loose and I don't think that a, heavy, likely out of balance, steel fan is doing them any good.
Kurt
If the bearings have play don't drive your car anywhere or the metal Fan will "tripan" the Rad. Please don't ask me how i know
- alan.barker
I set mine up as a puller so it would not shadow the radiator out front. And I fashioned a rear duct to exit the blast below out of coroplast. Otherwise the rad dumps heat back onto the motor whence it came. It's funny any interference with moving parts (the pulley especially) will sculpt the duct to an exact fit. I'm not sure if these refinements help, but as long as I was doing it, I thought I'd try. JOhn
- baileyman
