engine noise
PostPost by: seniorchristo » Fri Feb 03, 2023 10:51 pm
I have been trying to diagnose an engine noise that sounds like clattering valves or a loose timing chain. However I have eliminated these as possibilities and also replaced the lifter sleeves which has reduced but not completely quieted the noise. The noise starts at idle and continues up to about 2000 rpm. It is worse when letting off the accelerator.
I am wondering whether the chain hitting the inner water pump casting could cause a rattling noise? See photo. This photo is from another engine but I see the chain on my engine appears to be rubbing at the same point.
DSC01120 (2).jpg and
67 Elan Super Safety
67 Elan +2
PostPost by: pharriso » Fri Feb 03, 2023 11:06 pm
If the timing chain is hitting that boss then it must be loose...
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: seniorchristo » Sat Feb 04, 2023 1:56 am
The chain is not loose. Less than 1/2" up and down movement as specified by Lotus. It is a Dave Bean cartridge style timing case which may however vary from the Lotus unit.
67 Elan +2
PostPost by: englishmaninwales » Sat Feb 04, 2023 11:08 am
My aftermarket timing case with a separate water pump (Burton), the casting was inaccurate and required fettling to allow timing chain clearance.
Edit: It was on the opposite side, though, due to an inaccurately placed casting core for the coolant passageway.
1966 Elan S3 Coupe
1994 Caterham 7
