Cam Bearings and Hello from new forum member
New member just saying hello
I've been following the forum for awhile and decided to register as It's been a good read and source of information
I'm a mechanical engineer by trade and in the process of building a 1968 TC for a friend to fit in a Mk1 Escort
I'm struggling with the jackshaft bearings though and wondered if anyone can help?
The ones I've removed were FORD part numbers: 105E6261A 105E6262A 105E6263A
Which I believed were FORD standard sized items, I fitted the standard ones from BURTON and the jackshaft is tight
Before I start clocking the jackshaft up for straightness, I wonder if anybody has any suggestions or might have had this problem before?
Thanks in advance for any help
- perksy
Its very simple. Once new jackshaft bearings have been installed, they often have to be reamed to fit the shaft.
I have been lucky on occasion, and this has not been necessary, and unlucky, and it has. And it does not seem to be consistent with any particular brand of bearing either. ACL, original Ford, Vandervell. They sometimes need boring, and sometimes not. If the jackshaft turned okay in the block before removing, there wont be anything wrong with it, unless you dropped it
Welcome to the Board.
Leslie
Leslie
- 512BB
Hi Leslie
Thanks for the quick reply and the welcome
Jackshaft definitely not dropped, so it looks like a trip to the machine shop might well be in order
I've built a few engines now, but I'm enjoying the TC so far, Its nice to work on some 'old school' technology
- perksy
Local machine shop are aware of this issue and mention doing several before
Trouble is they want £180 plus VAT for machining and then the price of the bearings on top
I've just checked the jackshafts machined surface with a file and it doesn't appear very hard, Has anyone successfully span one of these in a lathe to correct the issue?
I'm thinking now of carrying out the short jackshaft conversion method and then spin it in the lathe to achieve a nice fit on the two remaining bearings?
- perksy
IF you install in shaft bearing by bearing you may be able to find just one is tight or misaligned, it’s a white metal shell and any high points can be easily scraped to size.
- Craven
perksy wrote:I'm thinking now of carrying out the short jackshaft conversion method and then spin it in the lathe to achieve a nice fit on the two remaining bearings?
The rear bearing has an oil feed that needs to be plugged if you shorten the jackshaft. The usual technique is to fit the bearing shell, but to make sure the oilway in the block doesn't align with the hole in the bearing. So if you go down this route, I am afraid you will be replacing the rear bearing.
Good luck.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
'Trouble is they want £180 plus VAT for machining and then the price of the bearings on top
No 1, you are being ripped off. The company that I use on occasion, charge me £40 to get a jackshaft to fit new bearings that I have already fitted. No 2, why do you need further new bearings? I understand that you have already fitted them.
'I've just checked the jackshafts machined surface with a file and it doesn't appear very hard, Has anyone successfully span one of these in a lathe to correct the issue?'
You can't do that, that's butchery. The problem is with the bearings, not the shaft.
'I'm thinking now of carrying out the short jackshaft conversion method and then spin it in the lathe to achieve a nice fit on the two remaining bearings?'
Craven wrote 'IF you install in shaft bearing by bearing you may be able to find just one is tight or misaligned, it’s a white metal shell and any high points can be easily scraped to size.
I think he meant to write 'If you install the bearings in the block, bearing by bearing' or even, if you insert the shaft in the block gradually, with the block in the vertical plain, you should be able to deduce which bearing is tight.
Have you tried that Pesky? I have sucessfully scraped, or more accurately, rubbed a tight jackshaft bearing with 1000 wet and dry, soaked in oil, to relieve a tight bearing.
Leslie
Leslie
- 512BB
I have hand scraped bearings to get the jackshaft to spin sufficently freely. You can see the high spots on the bearing if you turn the shaft a couple of times and need to scrape very carefuly on these high spots as the top layer of white metal is very very thin. Just spining theshaft by hand a few times can get the shaft freed up.
Just do yourself a favour and get them line bored by someone with the proper equipment. Yes the amount you have been quoted is way over the top. Take the shaft you will be using with you when you ask them to do the job.
If it were me I would not try rubbing soft bearings with any kind of abrasive. Particles of abrasive are liable to break off and embed themselves in the bearing
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
yes if removing high spots on a bearing by hand, scrape with the edge of a flat blade such as a small 150mm steel rule, do not use abrasive
You will need a half-round Scrapper.
I used to make them from old Files. Soften old File, make into Scrapper, re-harden. Apprentice job.
- alan.barker
Users browsing this forum: ajwheels and 8 guests
