Camshaft KCL2
Can anyone help with the settings for my camshafts stamped KCL2?
Cam has a lift of 8.8mm (0.346") duration is approximately 340 degrees.
message update:-
Both my camshafts are marked KCL2, I set up the exhaust cam ok, as per the L2 data.
I could not set the inlet cam ....eventually realised it's been "re-profiled"; the dwell angle is about 340 degrees (not the 320 degrees of the L2 ), lift is the similar. I don't understand why this has been done.
The only cam near this I can find is a full race one with 330 degrees dwell and greater lift, set at 60/90 timing.
Is anyone familiar with this set-up or can advise?
message update:-
- Bob3114
Presuming it is a Kent Cam L2 (KC L2) then this is what Kent list for it but are you sure it has a duration of 340 degrees.......that is wild! .......is it maybe 304degrees?
The camshafts were fitted by the previous owner who used the car for sprints.
The car was running reasonable well before having a oil feed problem, hence the head off etc.
Yes I think a camshaft change is a good idea, but not until some of the other issues are sorted, as budget permits.
I am hoping to put things back together this week and have a trial run, will update post then.
As for the oil feed problem….. will post later.
Bob
Bob
- Bob3114
