Timing chain adjuster screw
My engine has recently returned from rebuild by a specialist. The timing chain whines, I've removed the cam cover and the chain is much tighter than the recommended 1/2" of play. I've tried to adjust, but when I slacken the adjuster screw the locknut seizes on the thread before it seats on the abutment - I can't see whether the adjuster screw thread is damaged or covered in thread lock. Now the question - can I unscrew and remove the adjuster screw to examine the thread without anything falling off the other end or becoming displaced?
Thanks in advance!
Vernon
Thanks in advance!
Vernon
Elan S2 26/5614
Alfa Romeo Alfetta Berlina 1974
Westfield 7SE
Westfield 7SE
- quaybook
The adjustment screw is removed as a unit, you need to undo the large nut this will take the adjustment screw with it, self-explanatory when you see it, however there is a coil spring and tension plunger left in the hole just leave in place it shouldn’t go anywhere.
- Craven
