Timing chain tensioner problem
Hi All, need some advice. while reassembling the cams and timing chain in situ, I noticed I was missing the plunger/piston (see photo) placed first into the tensioner bore. I now believe it dropped into the timing chest but can’t see it. Is it possible it could drop past the timing chain and rest at the lowest part of the chest?
I must be losing it. Hopefully my last rebuild…..
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901 - Second Gear
It would be impossible for the plunger to get past the timing chain quadrant if you have the timing chain installed on the cams, so you will have to look for it elsewhere. Obviously you could drop it in from the top of the head, but surely you would have noticed / heard it drop.
Leslie
Leslie
- 512BB
Under normal circumstances it can not drop through. However i once dropped upon a situation were a standard engine had been fitted with a tall block longer chain and the plunger was right out and at an angle ready from dropping out. Luckily the engine had not been run. If it had run there would have been some damage.
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
Thank you Leslie and Mike. Found the plunger. All going back now.
Scott
Scott
CG901 - Second Gear
