Oil Pressure Sender - adaptor for block to sender
PostPost by: Andy Hamblin » Fri Aug 12, 2022 12:20 pm
Hi guys, The threaded hole in the block for the oil pressure sender (electrical, not capillary) is 1/4 inch and the thread on the sender itself is 1/8 inch NPT. So an adaptor is needed and it has to be a 90 degree elbow to avoid the sender fouling the rubber cooling hose from the heater to the block.
I have searched extensively and cannot find a supplier that has a 90 degree adaptor, 1/4" male to 1/8" NPT female.
Does anyone either have one or know where I can get one?
Andy
Sept 1970 Plus 2S, KOO38J Glacier Blue, 50/2432 (was Carnival Red)
Andy Hamblin
PostPost by: ericbushby » Fri Aug 12, 2022 6:37 pm
Hi Andy,
I cannot help with the angle adaptor, but are you sure you need it.
Mine is fine with a straight fitting and with the oil pressure tube passing under the heater hose.
It does just barely touch the hose but is not a problem.
Eric in Burnley
1967 S3SE DHC
PostPost by: snowyelan » Fri Aug 12, 2022 7:18 pm
https://ph.parker.com/us/en/pipe-fittin ... x-1-8-cd-s
You may have more luck finding parts to simply use a 1/4-1/8 bushing in a standard 1/4 street elbow.
Scott
45/9011
Hawkestone, On, Ca
snowyelan
PostPost by: Andy Hamblin » Fri Aug 12, 2022 7:59 pm
Thanks Eric - hadn't thought of that - gives me another option. on my engine, it still looks tight though, the line of the coolant hose runs pretty much across the line of the hole in the block
Thanks also Scott - that part is exactly what I need. i've asked for a quote. If its stupidly expensive, then I may have to do it with more than one connector, as you say.
Andy Hamblin
