Camshaft help
I am stripping down the engine from my Sprint. There engine has clearly been tuned, and it has been suggested the engine was fitted with L1 cams. I am a believer in trying to figure out what I am dealing with before I strip it down, so with the help of Youtube, I have taught myself about cam timing. Its a PITA.
I checked the clearances first and got.
Exhaust
1 - 0.004"
2 - 0.014"
3 - 0.013"
4 - 0.008"
Inlet
1 - no clearance
2 - 0.001"
3 - no clearance
4 - 0.003"
I measured the cams - they have a base circle diameter of 24.25mm and lift of 10.58mm (0.42"). The cams are marked VJ5 - which a bit of digging indicates they are Vegantune camshafts.
I messed around for ages measuring the timing. As best as I can figure, the Exhaust MOP is 105 degrees BTDC, the inlet MOP is 118 degrees ATDC. Measured duration is a very approximate 280 degrees.
The only info I could find on the cam on the web indicates that the cams should be timed to have an Exhaust MOP 110 degrees BTDC, inlet 105 degrees ATDC. Rohan's very helpful post on cams suggests that cams with 280 to 290 duration and lifts in the 0.40 to 0.44 range should have MOPs of 108 to 106 degrees, so the data I found on the web for the cam looks about right. The engine as set up currently is however a complete dog's breakfast.
I intend to rebuild the engine completely. Are my VJ5 cams a jewel worth persevering with? or should I mount them on the garage wall and buy modern known quantity camshafts?
Thanks as always for any feedback.
Exhaust
1 - 0.004"
2 - 0.014"
3 - 0.013"
4 - 0.008"
Inlet
1 - no clearance
2 - 0.001"
3 - no clearance
4 - 0.003"
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
KC VJ5 cam specs given to me by Kent cams are as follows (this is their version of the Vegantune cam, which as far as I'm aware is identical) :
Lift 0.350"
Duration 260 degrees (no details of whether this is @ 0.050" checking height, but it would make sense, given how short the quoted duration is).
MOP 108 degrees
0.010" clearance.
If that's correct, then perhaps your cams were either reprofiled using a cam that was a VJ5, or Vegantune VJ5 are different to Kent Cams VJ5, which Kent Cams didn't advise me that was the case.
The base circle you have mentioned is quite small - I've never seen any that small, but that doesn't mean they don't exist, just that's it's not normal practice.
How did you get the lift - did you measure cam follower movement? Or did you calculate it from length of cam minus base circle?
Lift 0.350"
MOP 108 degrees
0.010" clearance.
promotor - Fourth Gear
promotor wrote:The base circle you have mentioned is quite small - I've never seen any that small, but that doesn't mean they don't exist, just that's it's not normal practice.
Thanks for the response.
I may well have screwed up, but I used a digital vernier caliper to measure the base circle - so it it would have been tough to have got that wrong (although not impossible).
I used length of cam minus base circle for lift, so the actual valve lift would need to have the clearance deducted from this figure.
32 Standard 12
32 Standard 12
- Andy8421
Andy8421 wrote:promotor wrote:The base circle you have mentioned is quite small - I've never seen any that small, but that doesn't mean they don't exist, just that's it's not normal practice.
Looking at your cams they do look like they have been machined quite a lot so I would say the base circle is very small.
I would be considering the possibility that the cams aren't VJ5 specification any more!
I thought it strange that the VJ5 cam I had in my hand was only fast road spec as I was thinking the "5" possibly denoted phase 5, but that's what Kent advised.
What info have you got for the VJ5 cam? MOP figures only?
Those cams may have been dropped in with no cam timing done. The old sprockets could have been used and the timing done just by lining up the engraved marks. Are offset dowels fitted? If so then that’s a good sign that more care has been taken.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
2cams70 wrote:Those cams may have been dropped in with no cam timing done. The old sprockets could have been used and the timing done just by lining up the engraved marks. Are offset dowels fitted? If so then that’s a good sign that more care has been taken.
Just taken the cams out. Dowels are not offset, so it looks like the cams were just dropped in as you suspected.
32 Standard 12
32 Standard 12
- Andy8421
Craven wrote:Just from visual, turned surfaces between the cam lobes is very indicative of Vegan cams. Small base circle with this would perhaps be the grid method to get high lift from a standard cam.
Edit, They have been known to snap!!
Great.
It is looking more and more like these cams will become interesting ornaments. Given the lack of definitive timing information and the chance they could snap, I think I would do better to start with a known quantity.
Thanks again to all for the very helpful comments.
32 Standard 12
32 Standard 12
- Andy8421
promotor wrote:What info have you got for the VJ5 cam? MOP figures only?
Nothing definitive. Thread below makes reference to the VJ5:
https://lotuselan.net/forums/viewtopic.php?f=39&t=1788&start=
and this thread has a Vegantune spec sheet halfway down which may reference the VJ5, although as it promises 150BHP, I am not sure how reliable a source it is.
https://lotuselan.net/forums/viewtopic.php?f=39&t=19276
32 Standard 12
32 Standard 12
- Andy8421
Andy8421 wrote:promotor wrote:What info have you got for the VJ5 cam? MOP figures only?
I did a bit of research myself when this one came in an engine and as I also couldn't find anything definitive resorted to Kent Cams helpline.
Have you tried checking the duration on another lobe with clearance - exhaust number 4 is a good one to use - most aftermarket cams use 0.008"-0.010" clearance?
Hi Andy,
I was in conversation with Tony Ingram about the VJ5 cams and he confirmed the following info to me:
Hi Iain
The VJ5 is a very good profile. It was designed as a step up from the Sprint cam that gives around 5hp gain and needs no modifications to springs or piston valve reliefs.
It has 280 degrees of duration seat to seat and should be timed as follows-
Inlet fully open at 105 deg Exhaust fully open at 110 deg
Inlet clearance .006" Exhaust .010"
Jetting will vary depending what size main choke you are using.
This was always my favorite profile for a 135hp street engine.
Kind Regards,
Tony
Hi Iain
Kind Regards,
Tony
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
Looks like the cam has been reprofiled for higher lift and who knows what duration compared to the original VJ5. That may be good or maybe bad. If you have a local cam grinder they can measure up the profile to see what you have. The alternative is buy new cams to the profile suited your planned engine and use.
rgh0 wrote:Looks like the cam has been reprofiled for higher lift and who knows what duration compared to the original VJ5. That may be good or maybe bad. If you have a local cam grinder they can measure up the profile to see what you have. The alternative is buy new cams to the profile suited your planned engine and use.
Thanks Rohan, and thanks to all the others who have responded.
I have decided to go with new cams. Trying to reverse engineer 40 year old cams from a defunct company that may have been reground to a different profile with little or no documentation feels like hard work. I now have to figure out what cams to use.
I will come back for advice when I have done some research.
32 Standard 12
32 Standard 12
- Andy8421
So, after a bit of a hiatus, I have decided to move on with collecting bits for my restoration. Tim has kindly cross referenced my unit number and engine number with his records, and confirmed that my '71 convertible Sprint is indeed a '71 convertible Sprint, and that the engine block is the one it left the factory with. This has encouraged me to try and use as much of original car as I can. I have spent the last few years collecting tools, and I want to try to do as much of the work on the car as I can, but I am an electronic eng. not mech eng. so I would be very grateful for some advice as I move along.
As mentioned above, the head has had some work, and the cams appear to be Vegantune re-grinds. I considered persevering with the Vegantune cams, but I would rather start with a known quantity for such a key item. Having reviewed all the threads I can find on cam choice, the QED 420 camshaft seems to be the most recommended for 'fast road' use. A couple of questions to get me going:
1. QED list 3 flavours of 420 - a regrind, chilled cast or steel. I don't have virgin cams to regrind, so the choice for me is chilled cast or steel. For low mileage 'fast road' use, and perhaps the occasional track day, what should I be buying?
2. Back in the dark ages when I rebuilt Minis, it was usual to replace the followers when replacing the cam. Is the same true of the Lotus tappet bucket cam followers?
Thanks in advance for any replies.
Andy.
Andy.
32 Standard 12
32 Standard 12
- Andy8421
Personally i would use the cast iron cams but would modify them for the fitting of long sprocket bolts to reduce the risk of the cams breaking at the oiling groove on the first journal with the higher lift profile. This is probably not absolutely necessary for a QED 420 cam running the very low load Q55 springs. QED themselves do not do it, but then again QED are just a parts seller these days and appear to have lost all their detailed engine modification knowledge over the years. I believe Kent cams who make a similalr 0.420 lift profile cam will do the long sprocket bolt modification if requested.
Steel cams are stronger and dont require the long sprocket bolt modification. However steel is more prone to galling failures than cast iron, which is a surface failure due to micro welding between the cam lobe and follower. Thus its more problematic getting the cam and follower to bed properly on running in and not fail due to galling especially when running steel cams on steel followers and many followers you buy these days are steel though you still maybe able to get cast iron ones. However you may then run into other problems as you may need to use thinner steel followers depending on the set up of the valve train to accomodate the QED 420 lift. You can get steel followers with DLC coating or you can phosphate coat the cam and and followers and either of these treatments can help prevent the galling problem.
Always use a good assembly lube on the cams and followers and a good high ZDDP oil for running in the new engine which also helps prevent the galling failures which mainly occur during run in.
I would always use new followers with a new cam.
Users browsing this forum: Frogelan and 25 guests
