Identical cam sprockets? Is this normal? Photos.
PostPost by: berni29 » Tue May 31, 2022 9:06 pm
Hello Guys
I am just putting my twincam head back together today and looking at the cam sprockets they both seem identical. I thought they were supposed to be different. I know the cams are the same. Both sprockets have offset dowels in them,
Guidance appreciated!
Many thanks
Berni
IMG_4522.jpg and
IMG_4521.jpg and
berni29
PostPost by: types26/36 » Wed Jun 01, 2022 6:50 am
Both  cam sprockets as well as the jackshaft sprocket are the same, the only difference is that the exhaust sprocket and the inlet sprocket have their timing mark one tooth different (no mark on the jackshaft sprocket) normally only the exhaust sprocket was etched by Lotus with (EXH)
After market sprockets are usually etched and marked with both IN and EXH so they can be used on either.
types26/36
PostPost by: berni29 » Wed Jun 01, 2022 8:39 am
Hi Brian
Mystery solved thank you. I have looked at some pictures on the great and wise internet and it seems these are QED items according to the markings.
Thanks again
Berni
berni29
