Piston ring orientation
My oil control rings (which I'm re fitting) have no 'up or down' marks and one side has a very obvious bevel edge - would I be correct in saying that this edge should point down?
...these are the deep rings with slotted recesses and the separate spring oil retainer which fits behind
Jon
Jon
- jono
Sorry, I'm not sure I was clear.
One face of the ring has a square outer edge/arris and the other face has a pronounced bevelled outer edge/arris - are you saying that the bevelled face should be uppermost?
The ring is not a 'keystone' in cross section (it perfectly square)
- jono
jono wrote:Sorry, I'm not sure I was clear.
I'm not sure I understand where the bevel is if the ring is perfectly square... the bottom ring is usually made of 2 very thin blades...
in any case, if in doubt, I would attempt to check the installation recommendatinos of the ring or piston manufacturer... rings should be marked on the face that goes up (chamber side)
as for the general principle :
https://www.performancemotorsports.eu/support/instructions-terminology/piston-ring-tech/
S4SE 36/8198
nmauduit - Coveted Fifth Gear
This ring is not a two part - it's as shown here and it uses a separate expander spring behind the ring.
Unfortunately I do not know the ring manufacturer as these are +30 year old pistons and rings.
In the photo I have placed the ring with the bevel (or perhaps better described as a 'chamfer') at the bottom
- jono
jono wrote:This ring is not a two part - it's as shown here and it uses a separate expander spring behind the ring.
Jono,
The reproduction rings you get now have two chamfers on them - they are both on the top side of each "micro-land" of the type of oil rings similar in design to yours in the photo.
So, the chamfers face upwards, and the sharp edges (ie non-chamfered) face downwards to scrape the oil back into the sump.
If you only have one chamfer (can't really tell in your photo how many you have) then the chamfer would still want to face up and the sharp edge face down to scape oil back into the sump.
promotor - Fourth Gear
Al,
That's perfect thank you and makes good sense now you explain it.
Oddly enough I have a new set of Goetze rings for a spare engine and the oil rings, though the same format, have no chamfers on either face!
I only have one chamfer and have set it to the bottom so I now need to correct that before I assemble the engine - glad I checked!
Thanks again
Jon
Thanks again
Jon
- jono
jono wrote:Al,
Thanks again
Jon
You're welcome, jono.
I've just checked a few different new old stock pistons and they have the chamfer(s) in the same orientation, and the rings have "top" marked on them so we can be confident the manufacturers' all agree they're meant to be that way!
