Crank and waterpump pullies
PostPost by: HCA » Sat Mar 12, 2022 9:11 pm
Please can/will someone confirm that crossflow front crank pullies and waterpump pulley PCD are interchangeable with pre-crossflow?
To be precise, will this kit fit the Elan Twin Cam?
https://anemboengineering.co.uk/ford-x- ... drive-kit/
Thanks!
Hal Adams
Evora SR
Elan +2
HCA
PostPost by: 2cams70 » Sun Mar 13, 2022 7:18 am
The position of the belt relative to the block is the same between the xflow and the LTC. The crankshaft pulley is different in offset by about 1mm because the timing chain sprocket is different in thickness. The different in offset compensates for the difference in sprocket thickness so the belt ends up in the same position. You are best to ask the supplier if this will fit or not. There’s less clearance for the water pump pulley on a LTC because of the thickness of the front cover and this one may not fit
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: fatboyoz » Sun Mar 13, 2022 8:18 am
Hi Hal,
I have had this kit from Burton Power fitted to my S4 for the last 12 years.
https://www.burtonpower.com/water-pump- ... 225dk.html
The toothed belt can be left quite loose.
Colin.
quote="HCA"]Please can/will someone confirm that crossflow front crank pullies and waterpump pulley PCD are interchangeable with pre-crossflow?
Thanks![/quote]
'68 S4 DHC
fatboyoz
PostPost by: TBG » Sun Mar 13, 2022 8:42 am
Just out of interest I fitted a toothed belt system to mine some years ago and the belts kept snapping after not a long time. This was after long high speed runs across the continent. Went back to belts and no more problems. D
TBG
PostPost by: HCA » Sun Mar 13, 2022 8:49 am
Thanks Colin, that is great and answers the question!
I tried Burton for this, but all I found was one for racing - just the crank and water pump pulley. I will call them on Monday and order.
Maybe the same reason, but I want to minimise the load on my waterpump. Interesting that you have had this kit on the car for twelve years - may I assume that during this time, the waterpump has not been touched..?
TBG - interesting! Did you never get a reason for this happening?
Hal Adams
Evora SR
Elan +2
HCA
PostPost by: TBG » Sun Mar 13, 2022 10:35 pm
Hal - I think the thoughts from those in the know was some sort of resonance causing the fractures. I fitted them to reduce the load on the water pump so that was a busted flush. I have bored all of you on here for a long time with my twin belt system that works so well. Any one want drawings just let me know. Rather an old photo - better set up now. D
DSC04780.JPG and
TBG
PostPost by: bitsobrits » Mon Mar 14, 2022 1:17 am
I would very much be interested in a dimensioned drawing for the dual crank pulley.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PostPost by: fatboyoz » Mon Mar 14, 2022 1:55 am
Hi Hal,
Correct, fitted the Gilmer drive (toothed drive) to run the belt at minimum tension to prolong the life of the water pump. I have done 60,000 miles since water pump and gilmer drive fitted. I believe, that this is much longer than most (stressing most) twincam water pumps last. I do change coolant on a regular basis, and keep an eye on the water pump weep hole for any telltail signs of failure.
I have not had to change the toothed belt in all that time. I do carry a spare though.
Just remembered, the crankshaft pulley has to be notched to coincide with TDC.
Cheers Colin.
quote="HCA"]Thanks Colin, that is great and answers the question!
TBG - interesting! Did you never get a reason for this happening?[/quote]
'68 S4 DHC
fatboyoz
PostPost by: TBG » Mon Mar 14, 2022 9:03 am
Bitso here we go!! D
Alernator pulley.02.jpg and
Alternator pulley.01.jpg and
Alternator pulley.03.jpg and
TBG
