Replace Rope Seal with Rubber Lip type?
I had my twin cam engine rebuilt last year and its all good except for oil leaks at both ends from the crank seals. Its a rope seal at the rear.
It'll have to come out again, as the leaks are too serious to live with - is it possible to replace the rope seal at the rear with a rubber lip seal?
Sept 1970 Plus 2S, KOO38J Glacier Blue, 50/2432 (was Carnival Red)
- Andy Hamblin
Mazzini wrote:yes, but you will need a later 6 bolt sump.
Many thanks. Is that all I'll need or are there other parts that will need changing to accomodate the 6 bolt sump?
- Andy Hamblin
Andy Hamblin wrote:Mazzini wrote:yes, but you will need a later 6 bolt sump.
You will need a seal housing and the seal of course. Both readily available from the likes of QED for £70 odd. The sump will be a nightmare. You will not find one under £350. There are some converted ones on ebay, but be careful as many were badly converted.
Hal Adams
Evora SR
Elan +2
Evora SR
Elan +2
HCA - Coveted Fifth Gear
HCA wrote:Andy Hamblin wrote:Mazzini wrote:yes, but you will need a later 6 bolt sump.
Many thanks, that's useful. Probably rules it out in reality.
Appreciate your help guys.
- Andy Hamblin
You will need a modified seal housing otherwise you will have to change the crank as well.
Mazzini - Coveted Fifth Gear
Read here for 4 bolt conversion, I can't recall who is making the kit in the UK but I think he is somewhere in the Midlands area
viewtopic.php?f=37&t=962&start=#p72335
- tonyabacus
Users browsing this forum: No registered users and 49 guests
