Fidanza Aluminum Flywheel and stalling or Donuts & stalling?
I have a 67 FHC with a 3.77 differential and the later 4 speed transmission with the lower first gear. This I purchased from a previous owner who put in a 1700 cc block (with standard head and webers) and also put in a Fidnaza aluminum flywheel.
To start the car off from a traffic light, I have always had to feather the clutch and burn it a bit to prevent stalling. My question is:
Is this due to the lightweight flywheel only, or do my Rotoflex couplings also contribute to having a little trouble getting away from a light?
I have heard a car with Rotoflex is a bit harder to drive than one with a driveshaft conversion, and was wondering if a driveshaft conversion to CV joints would help with my takeoff from the lights, while leaving the Fidnaza flywheel in place.
Thanks for any insight!
Bill Moore
Bill Moore
1967 Lotus Elan FHC Spyder Chassis
1972 MGB (since 1975)
- billmoore42
You need to look at a range of issues before concluding what the problem is. Rotoflexes are only a potential issue if you have to feather the clutch due to surge in the drive train when taking off. Even then the surge may be due to other factors such as the engine and gearbox mounts
It also unlikely that an aluminium flywheel alone would be the problem especially with a 1700cc engine 3.77 diff and semi close gearbox, though the flywheel may be a part contributor if other issues present
i.e. Other issues to consider
The carb tune at low throttle openings
What sort of cam is fitted
What compression ratio
The ignition timing curve
What sort of clutch plate and pressure plate assembly and is it still in good condition
Rohan and 2Cams:
Thanks for the comments. The car has quite a bit of power, solid motor mounts, and I believe a standard cam. So it looks like I might gain a little by converting from donuts to CV driveshafts as far as driveability.
The problem is, I drive it to work twice a week, and have about 16 stoplights on my way.
Bill Moore
Bill Moore
- billmoore42
Are the Doughnuts the original type or the later sprint type with the interlleaves.
The sprint type are less elastic.
It could also be the Flywheel needs to be resurfaced.
- alan.barker
As well as taking the Aluminium flywheel to the metal recyclers I'd recommend getting rid of the solid engine mounts pronto unless you have some teeth fillings you would like to remove!
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Thanks, I have rubber engine mounts but it sounds like the aluminum flywheel is the root cause of the problem. I think this would not be a problem if were retired and just drove on the abundant canyon roads around here, but driving through the city to work can be tiresome, and also can occasionally induce a bit of paranoia, as my car is so small compared to the Challengers and SUVs that are so prevalent here.
Bill Moore
Bill Moore
- billmoore42
Sorry to be late coming to this discussion.
I have to say I disagree with most of the previous comments. I have a 1720cc Elan with a Fidanza aluminium flywheel, 3:55 diff and close ratio box and I have absolutely zero problems as you have described! I do however, have sliding spline driveshafts-no rubber for this ducky!
(edited)
(edited)
'65 S2 4844
- Davidb
Also coming in late, but I've run an aluminum flywheel for the last 30+ years in my S1 Elan with no issues similar to yours. 3.55 rear end, semi-close gearbox, 185/60 tires and 1720cc. I've run an aluminum flywheel in most of my sports cars over the years with no issues, including my current E-type Jag (18 years and counting).
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
I have a Fidanza aluminum flywheel in my Plus2, equipped with a 2L Zetec, close ratio trans, and a 3.55 diff. No problems what so ever after 3 years of operation. If you let the clutch out without giving it some gas, it is a bit dicey, however a small increase in rpm will get it moving without issues.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Getting the Elan off the line has always been a 'process' - not a massive process but still a process and once learned, makes the 'launch' easy.
First learned on in an S2 while driving in London.
First time I got behind the wheel of a Plus 2 with a 2.0L Zetec with 170+hp and equally good torque I almost stalled/kangarooed it.
Once I made the mostly mental adjustment it was just like driving any other (rotoflex) Elan.
- Slowtus
Thanks for all the comments, it appears aluminum flywheels are a subject of some debate. It sounds like switching out my Rotoflex (a shame, as they are in perfect shape and only 2 years old) with driveshafts will at least help a bit with the start from the traffic light.
- billmoore42
