Odd twin cam rope seal sump
I recall a friend who emigrated to Canada told me everyone had a heated sump in their car and plugged it into a power point every winter night. But that tube doesn't seem to emerge from the sump in any manner. I can't see how it would help the baffle either, which itself has been crudely cut away.
Meg
The sump comes from a 1500 pre crossflow engine that has been converted for use in a marine application and the pipes are part of the cooling system. There were a number of companies that modified the pre crossflow and crossflow engines for use in boats in the 60s and 70s . A company called Watermoto called their 1500cc unit the
“ Sea Tiger “ and the 997cc unit the “ Sea Wolf “
I was fortunate to find that the last marine engine that l purchased was based on a Lotus 681F “ L “ Block.
Nick
Nick
- avro
batfish wrote: ..Quite crudely baffled and with 2 drain plugs.
Andy
Why? It's easy to lean a boat a bit to help the drainage. I suspect some instrument like a temperature gauge might have been fitted.
Great resolution of your original question.
Meg
