Plus 2 Radiator Brackets
PostPost by: 111Robin » Mon Dec 27, 2021 6:36 pm
The radiator on my Plus 2 is secured to the body by two crudely bent pieces of aluminium. Are these brackets listed on Ebay the correct items ?. I don't see them listed separately anywhere so I'm not sure what they should look like.
https://www.ebay.co.uk/itm/Lotus-Elan-P ... ect=mobile
111Robin
PostPost by: draenog » Mon Dec 27, 2021 6:46 pm
Apart from early examples, the +2 had a narrow radiator fitted with large brackets/wings filling up the space (both from a Triumph Spitfire). Those brackets look correct for the narrow radiator. You can see them fitted to a radiator in another ebay item https://www.ebay.co.uk/itm/324852730019.
draenog
PostPost by: 111Robin » Mon Dec 27, 2021 6:52 pm
Thanks. So I should be able to source the brackets from a Triumph parts supplier if they are identical .
111Robin
PostPost by: draenog » Mon Dec 27, 2021 7:13 pm
Theoretically yes, but they don't look to be available (looked on Canley and Rimmer Bros). Also Lotus sometimes made modifications to the parts they got from others, so it's usually better to get original +2 items (but not in this case).
draenog
PostPost by: 111Robin » Mon Dec 27, 2021 7:31 pm
Thanks, I also checked Rimmers. I just thought they might be cheaper if not listed as a Lotus part but the Ebay ones would be fine.
111Robin
PostPost by: CBUEB1771 » Mon Dec 27, 2021 9:52 pm
You might also try Spyder. From them I have purchased a few original +2 parts which are removed for a Zetec conversion. I doubt very much that they retain the original water radiator mounts in their conversion.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: 111Robin » Mon Dec 27, 2021 10:36 pm
Thanks, certainly worth a try.
111Robin
PostPost by: pharriso » Mon Dec 27, 2021 10:40 pm
111Robin wrote:Thanks, certainly worth a try.
What am I missing? The ones in your original post on eBay are the correct ones...
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: CBUEB1771 » Mon Dec 27, 2021 11:01 pm
I agree that the ones shown on Ebay are correct but they might also be gone. Supply chains are tight everywhere. :wink:
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: pharriso » Mon Dec 27, 2021 11:15 pm
In which case I no doubt have a spare pair in my basement somewhere..... :roll:
Phil Harrison
PostPost by: 111Robin » Mon Dec 27, 2021 11:28 pm
They are being auctioned not fixed price. The starting bid is ok but I don't want to pay much more so will just keep an eye on it.
111Robin
PostPost by: CBUEB1771 » Tue Dec 28, 2021 2:38 am
The radiator brackets on eBay do not seem to have the the 90 degree angle pieces which attach them to the body shell. Perhaps you still have these with your aluminum brackets. The Lotus part numbers for these are 050 K 0063 and 050 K 0064. Another important item is the pair of blanking plates which help to lessen the amount of air that "leaks" over the top of the radiator brackets when you want all of the air entering the nose to go through the radiator core. The Lotus part numbers for the blanking plates are A050 K 0082 and A050 K0083. I see there is also a set of these blanking plates also on eBay.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: 111Robin » Tue Dec 28, 2021 8:50 am
CBUEB1771 wrote:The radiator brackets on eBay do not seem to have the the 90 degree angle pieces which attach them to the body shell. Perhaps you still have these with your aluminum brackets. The Lotus part numbers for these are 050 K 0063 and 050 K 0064. Another important item is the pair of blanking plates which help to lessen the amount of air that "leaks" over the top of the radiator brackets when you want all of the air entering the nose to go through the radiator core. The Lotus part numbers for the blanking plates are A050 K 0082 and A050 K0083. I see there is also a set of these blanking plates also on eBay.
Thanks, would you mind posting a link to the blanking plates as I don't see them when I perform a search.
111Robin
PostPost by: jono » Tue Dec 28, 2021 10:14 am
Hi Robin,
I have an original pair of these brackets from when I converted my last plus 2 to a Cliveyboy wide rad.
PM me if you are still looking.
Jon
PostPost by: 111Robin » Tue Dec 28, 2021 12:02 pm
In retrospect, looking at my radiator position in the photos (I don't have access to it just now to measure it) and looking at that radiator assembly on Ebay, I think I have the earlier wide radiator hence the wide brackets aren't required. This being so, what are the original brackets that would need to be used ?.
Screenshot_20211228-115704_Drive.jpg and
111Robin
Next
