Cylinder Head Studs
Hello all
Could someone please advise what the size and type of thread is used for the 8 studs that screw into the head and hold down the cam cover on the TC engine.
I am not referring to the thread on the top of the stud, that the Seloc washers and nylon nuts screw onto, rather I refer to the bottom end of those studs that screw into the head itself.
Thank you
Thank you
- J J DIKKE
Hi J.J.
I just checked a spare new stud and it is 5/16" UNC
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
JJ,
As Eric says, 5/16” UNC. These studs have an unusual end on them the thread has been machined off and the end radiused. Do you have a sample to copy? If not I could send you an old one, but do not use this sample as it has been over tightened and is stretched.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
Users browsing this forum: checkrail, Frogelan and 21 guests
