Ignition Timing With Delortto Carbs
My car is a standard S4 with Delortto DHLA40 carbs. I have just been checking the ignition timing at idle using a strobe. It appears to be just short of the first timing marker i.e. about 8 degrees. Is that correct? If not, and I have to rotate the distributor a small amount which direction do you turn it for advancing and retarding? Thanks for any advice.
- William2
William,
Viewed from the top, the rotor arm rotates anti clockwise. To advance the ignition, you need to rotate the distributor body clockwise.
The published literature confuses crankshaft degrees with distributor degrees, so be careful. There are a number of threads on this. I am afraid I don't have the specific details for timing using Dellorto carbs.
Andy.
Andy.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
