Running rough, back firing and cutting out
Help and advice appreciated!
I have a 2000 mile post rebuild 150 bhp TC running on 40DCOE Webers. It has the following symptoms which I know must be related to the engine, carbs or distributor as the engine unit has been in 2 Elans and the same symptoms have occurred in both cars.
Here is what happens:-
- car starts well and runs well to warm
- the symptoms occur either when the engine starts to run hot in traffic and also during a run, at normal temperature, after 10-15 miles
- the initial symptoms are poor running which gets worse over a couple of minutes and ends with the car losing power, back firing and then cutting out
- the car will not initially start but 20-30 minutes later the symptoms have gone and the car sill start nicely
- after this process, the plugs are oily, not sure if this is cause or effect of the poor running and cut out
It has done this on different coils, with both electric and standard fuel pumps and after fresh plugs. It runs an electronic ignition and the sensor has been changed too.
Suggestions and any insight very much welcomed!!
David
David
- dunclentdr1
This may sound counterintuitive, but try changing back to points and condenser. I have had the Crane optical and the pertronix fail due to heat.
I would safely say my Stromberg type 45 distributor is doing the same thing right now.
viewtopic.php?f=39&t=49626
I suspect if I didn’t adjust timing, setting the idle higher. It would do what you are experiencing with your engines.
I will get some time when kids are at camp tomorrow if I dont have to work to fit a different distributor.
Love your Mother
Earth
Love your Mother
Earth
David,
In you list of parts you have replaced, you don't mention distributor cap or rotor arm. I have experienced similar symptoms that eventually were traced to a distributor cap that became conductive when hot. I have also had rotor arms fail with similar outcomes.
I now buy my ignition components from 'The Distributor Doctor' and haven't had any problems since.
Good luck.
Good luck.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Hi David
I had similar problems recently, as documented viewtopic.php?f=38&t=49466
Agree with Andy that the distributor cap or rotor arm are possible culprits and Martin aka Distributor Doctor is very helpful.
Also check the 12v ignition feed on the back of ignition switch as mine was intermittently losing contact and causing cutting out.
I found the spark plug testers very useful. This gives a visual indication whether you are getting HT to the plugs, with the engine running.
Good luck!
Good luck!
Lotus Elan Sprint FHC 1973
RichardS - Fourth Gear
Plus one for the rotor arm.
You have described exactly how mine behaved.
It is probably a thermal fault and it takes half an hour for the engine heat to reach the distributor components and to cool down again. The missing spark causes unburnt fuel in the exhaust which is ignited with the next good firing.
best of luck
Eric in Burnley
1967 S3SE DHC
best of luck
Eric in Burnley
1967 S3SE DHC
- ericbushby
Thanks for all the suggestions - I am going to start with the distributor - new rotor arm and cap and then back to points if that doesn't sort it.
David
David
- dunclentdr1
