Oil pump gasket
PostPost by: 2cams70 » Sat Jun 19, 2021 3:30 am
Has anyone tried using a Ford Fiesta oil pump gasket? Appears to me to be the best type you can get. Burton's sell one which looks to be the same as the Ford OEM item for the Fiesta. It seems to be a steel laminate construction. I bought one to check it out. I see no reason why it can't be used in Lotus Twin Cam / Ford RWD Kent applications however I'm interested to know if anyone previously has used one. As far as I'm aware the Fiesta pump is pretty similar to the Ford RWD Kent one apart from different oil filter and PRV location. Pictures below show the Kent pump, original Ford OEM gasket for the LTC and Burton's supplied Ford Fiesta gasket.
IMG_2685[1].JPG and
IMG_2684[1].JPG and
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: 2cams70 » Sat Oct 02, 2021 4:13 am
I posted about this a while ago and received no response. As an update I have since built up a Ford/Burman high pressure / high volume oil pump using a combination of NOS Ford and Triumph parts and am about to fit it.
Initial impression of this gasket designed to the latest Ford specification are good. It's of a one piece steel construction and a continuous raised section provides the sealing lip. Similar principle to an MLS head gasket just without the "ML" bit - just an "S" gasket in other words!
Although originally designed for the later Valencia series Ford engines I can't see any good reason why it also wouldn't work on any Kent based engine. It would appear to be the best gasket to use - plus it's cheap!
One proviso though is that it does block of the PRV oil return opening in the block. This is no issue with all the later design pumps that recirculate PRV oil direct to the pump inlet port rather than to the sump - i.e 711M and 731M part number spin-on filter type bodies (virtually all of the new pattern pumps are to this design as well) . It will not work without modification with the canister style pump or the 701M spin-on filter pump.
Here it is here:
https://www.burtonpower.com/oil-pump-ga ... p710a.html
I think it's still available from Ford directly as well. Used in the Valencia based industrial engines and early 2000's Ford Ka.
Pictures attached. Still interested in comments from anyone who may have used this gasket previously.
IMG_2740[1].JPG and
IMG_2739[1].JPG and
IMG_2738[1].JPG and
IMG_2737[1].JPG and
IMG_2736[1].JPG and
