Static Compression ratio (on California gas,91 octane)
Couple of questions regards optimum Compression ratio (on California gas)
Q1
What is the highest static compression ratios are people on the west coast of the US building there engines to that are intended to run on the 91 pump gas?
Q2 what was there dynamic CR measured after build?
Q1
holywood3645 - Fourth Gear
10.3 CR California pump gas 91
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
I concur with our Napa lad. I can do 10.5 with B cams. Dynamic compression numbers can vary depending on: displacement, cam profile, etc. My 1725 cc LB block, Stromberg head will provide 195 psi. This is in my Elite/Elan MK II with a C-4 automatic gearbox. Elan S2 frame, stretched 4.125 inches to accommodate the Elite wheel base, full adjustable suspension and re enforced, all on our 15 inch wire wheels. She did gain a bit of weight. Had to use the Stromberg head as the C-4 is vacuum controlled. Hope this is helpful. Cheers. Mike, only 45 minutes from Napa.
[email protected] or (5l0) 232-7764
- Mike Ostrov
Please... I appreciate some additional feedback
While I'm not in California, we have 91 octane locally, and my 1720cc twincam (fully ported, large valves, high lift/short duration cams) runs just a bit over 10.3 static with no issues/pinking etc on the 91 octane. It does run a custom curve in the distributor with total advance listed to something like 28 degrees IIRC.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
