Variations in Timing Chain Tensioner housing nut
I am in the middle of a cylinder head changeover (as you already know by now ) & at the stage of setting the cam timing & adjusting the chain tension.
The thread on the old tensioner screw was a little beaten up, so I grabbed a spare assembly that I happened to have & assembled it into the front cover. Only problem is it bottoms out before the sealing washer is clamped:
Took the tensioner assembly out again & compared the housing nut of the "new" assembly to the old one:
The threaded section is .110" longer.
So I will use the "old" housing nut with the "new" Tensioner screw...
Anyone know what's going on with the difference in the housing nuts / assemblies? I thought all parts were original...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Lotus changed the design of the front cover may be around 1966 - 1967 and introduced a reinforcing web on the cover where the adjuster screws in. Maybe they changed the screw in adjuster length at the same time ??? Another unrecorded Lotus change and a great find. I must go back to some of my old covers and adjusters to see what I can find
The one on the left is a repro. one and has stretched. The repro. ones are thinner at the neck and can't take the torque if you tighten to the workshop manual torque figure.
Do yourself a big favour and do not use any reproduction tensioner nuts regardless of supplier . Always use an original one. The repro. tensioner screws are OK but not the nuts. It's not a component that wears so ok to just re-use.
I speak from experience on this one!
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
On my car, a replacement was fitted. It was an M8 allen screw adjuster, so incompatible with the original. The whole settup was kind of „handcrafted by incompetent persons“. I got an original one... but it came like this...
By chance, I had a thread rerolling tool I bought for the outboard driveshaft, that was killed by a stover nut. So the original adjuster screw with the same tpi could be restored.
Anna
Anna
1965 S2
- Emma-Knight
