Cylinder Head Oil splash plate
This plate bolts down under the Cam cap washers/nuts near the oil filler & deflects oil from being thrown up at the Oil fill cap & stopping the leak at the cap seal.
Here's the design if anyones interested & a drawing to reproduce
A picture of the plate in position on the cylinder head:
Thanks to John Clegg for the idea...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
If I were to implement such a mod, I would do it as was done in the "good old days" according to your link, i.e. above the camshaft bearing nuts, not below...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Yes, nut not required , just held in place by the posts/nuts and cam cover/ribs ( and a little spring tension )...
nmauduit wrote:If I were to implement such a mod, I would do it as was done in the "good old days" according to your link, i.e. above the camshaft bearing nuts, not below...
Why? could you elaborate please
Phil Harrison
pharriso wrote:nmauduit wrote:If I were to implement such a mod, I would do it as was done in the "good old days" according to your link, i.e. above the camshaft bearing nuts, not below...
I'd rather have the camshaft bearings held the way they were intended to (without risking side stress or poor setting by having non independent fasteners), and I'd rather be able to remove the plate without messing with the camshaft ... having the plate above would also help with high lift profile and would allow for a lighter alloy plate while a steel one would be required below the main fastener.
But in any case I prefer being able to see what's going on through the oil filling hole, and from all places that is not where I have leaks so far so I leave it as is.
S4SE 36/8198
Users browsing this forum: Ianashdown and 35 guests
