Correct Pressure Rating For Radiator Cap
PostPost by: William2 » Fri Jan 29, 2021 9:39 am
What is the correct pressure rating for the radiator cap and are they the same as fitted to certain Triumphs?
William2
PostPost by: pharriso » Fri Jan 29, 2021 2:24 pm
7 or 10 PSI is the norm, yes similar to Triumphs.
If you have the recuperation system make sure you get a cap with 2 rubber seals. In the US Stant part #10228 is 7psi & Part # 10237 is 10psi, both with the correct sealing.
Phil Harrison
1972 Elan Sprint 0260K
