Engine rebuild
I have disasamble the engine from my s3 and the pistons are in good condition. The pistons are 0.30 and are printed the number 18950. Anyone knows wich type of piston is? I need a new piston ring set.
Where can I find the rings?
In the cylinder head is stamped 26e 311. Someone knows the type of cylinder head?
- Dieschelan
I source most of my engine part from QED (no affiliation) ...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
I have another doubt. The pistons have small valve cuts. Can I use these pistons with a big valve conversion?
Diego
Diego
- Dieschelan
18950 are AE / Hepolite part numbers for Cast pistons.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Dieschelan wrote:I have another doubt. The pistons have small valve cuts. Can I use these pistons with a big valve conversion?
Diego
These pistons are fine for anything up to Sprint size valves and cams. Anything larger and you'll require deeper pockets. In fact it's best not to have pockets any deeper than required. Combustion is more efficient without lumps and bumps all over the pistons. This is why Lotus themselves went from large pockets on the pistons to small pockets on these engines. You can check them for clearance during a trial build of the engine in any case.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2015 Honda City 5spd.
- 2cams70
if you are keeping the original camshafts you should be fine - in case of any doubt, you can always do a dry fit with plasticine to check actual piston clearance...
S4SE 36/8198
I believe I have the same pistons, except mine were 0.040" over. Standard piston rings from Burton's is what I used.
Elan +2 #0245
Exige S2 Supercharged
Elan +2 #0245
- Chrispy
