Payen AF 880 orientation
Hello,
I have a Payen AF880 head gasket. Which side goes up? The only way it would fit is copper up and I am not sure if that is correct.
Max
Max
Lotus Elan S4
Alfa Romeo GTV6
Alfa Romeo GTV6
- madmaxsiegl
You can't fit the head gasket the wrong way round - the holes etc will be in the wrong place if you do. But to answer your question, the copper side faces the cylinder head face.
promotor - Fourth Gear
if it's designed for a crossflow rather than a Lotus Twin Cam, I'd be very cautious to save on that, double checking oil and water passageways etc (read : I would install a proper head gasket)...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Thanks for the responses.
This is the head gasket. As said before, copper side up is the only way it fits. So, technically it is the correct one it seems.
Max
Max
Lotus Elan S4
Alfa Romeo GTV6
Alfa Romeo GTV6
- madmaxsiegl
Might be worth double checking the small water flow holes and the oilway location....they may need a little fettling..
Users browsing this forum: AshleyPark and 11 guests
