Using Tap Water
You can buy the Coolant/Antifreeze that you don't need to mix with water.
I use an Etylene Glycol coolant and no need to add water.
When you drain the Cooling System try to drain 100%.
That means remove hoses for Heater at the Engine end and blowed copressed air in heater Hose at Thermostat to empty heater Mattrix. Maybe you could flush heater through first. You will be surprised at the dirt that comes out.
- alan.barker
Well at £3.90 for 5litres from Halfords for de-ionised water I wouldn't have thought would break the bank anyway so why the concern?
https://www.halfords.com/motoring/batte ... x2EALw_wcB
Alan.
Alan.
'71 +2 S130/ 5speed Type9.
- alanr
It depends on your local tap water quality and specifically its amount of various dissolved salts ( also called "hard water" if lots of dissolved salt ions). In Melbourne its not a problem as our tap water quality is very low in salts, but that is not common around the world. I would buy deionised water to add to concentrate or buy the pre diluted coolant in most of the world.
In West Sussex and Hampshire the water is very hard.
Where William lives. Lived most of my life in or near Portsmouth. Always changing Tap washers and Descaling the Kettle a real pain.
Car Rads love it So do Windscreen Washers
- alan.barker
William2 wrote:Is it ok to use tap water when you change the antifreeze or must you use de-ionised? I live in a hard water area if that makes any difference.
Regrettably I used just water, without additives, for many years and it was a big mistake. Without the lubrication effect of the additives the water pump seals don't last very long and without the anti-aluminium corrosion additive you get problems with the head and corrosion of the water outlet on the front cover.
I always use de-ionised water with anti-freeze, about £1.50 for 2.5 ltrs from Asda. Mix that with a good brand of ant-freeze and you're good to go. I have two Twincams with AL2 heads, the Lotus, and an Alfa 105, so imperative to use as above to keep things right.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
Previous :-
- elans3
I use the water from my dehumidifier, you could also use condensate from many tumble driers.
- mikealdren
