Best way of draining Antifreeze
You should have a drain tap in the bottom header of the radiator unless you have a non standard after market unit. This leaves a small amount of coolant in the bottom of the block and sitting in the heater.
If you want to remove all the remaining coolant then open the drain tap that was on the left rear of the block to drain the remaining coolant in the block. Many of these have been replaced with plugs over the years. Also remove the heater hoses and flush with clean water and then blow out with air.
