Elan s3 electronic radiator fan
PostPost by: Dieschelan » Sun Jan 03, 2021 4:23 pm
I’m looking for an electronic fan for a s3. Is possible to use the stock radiator or should I go for an aluminium radiator.
Where can I find an electronic fan for the s3?
Diego
Dieschelan
PostPost by: RichardHawkins » Sun Jan 03, 2021 7:51 pm
I bought mine from Cool Experts in Nottingham UK. I would have thought you could find something nearer home.
Richard Hawkins
RichardHawkins
PostPost by: TBG » Sun Jan 03, 2021 10:51 pm
Mine came from Coolexperts. Beautiful quality with twin Revotec fans - brilliant.
DSCN2684.JPG and
TBG
PostPost by: elans3 » Mon Jan 04, 2021 10:36 am
If your radiator is in good condition, you don't need the expense of an aluminium radiator, just a single Kenlowe. Revotec, Spal, Pacet fan of the right diameter.
If you buy a kit, you'll get the switching, mounting & thermostat bits with it too.
I have had Kenlowe fans in the past, very high quality . If you have an S3, you'll have the wider radiator anyway, much better than the short earlier version.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
elans3
PostPost by: TBG » Mon Jan 04, 2021 11:48 am
"you don't need the expense of an aluminium radiator"
Looks nice though!! :shock:
TBG
PostPost by: MrBonus » Mon Jan 04, 2021 7:08 pm
My S3 has an original radiator and a single 10.5 inch fan with an 74degree C thermostat. I have let the car idle for 15 minutes in 95 degree F humid heat and once the car hits 88 on the gauge, the fan kicks on and drops it down to 82ish degrees and can hold it indefinitely.
If I run the car hard on back roads, I can't even get the fan to come on in any weather as long as the car is moving, and that's driving at a sustained 4000+ RPM clip.
1967 Lotus Elan Coupe - Super Safety
2019 Tesla Model 3 Performance
1973 Ford F100 4x4
MrBonus
PostPost by: elated » Mon Jan 04, 2021 7:18 pm
Presumably that is what "mirror-finish" paintwork looks like!
Gordon
elated
PostPost by: MrBonus » Mon Jan 04, 2021 7:23 pm
elated wrote:Presumably that is what "mirror-finish" paintwork looks like!
Gordon
:lol:
The car was restored in the mid 90s, and the story I was told was the restorer dropped the car off at the body shop and asked for BRG. The paint shop, in the infancy of mobile internet, picked some horrid lime green and when the owner came to retrieve the car, he was completely appalled and demanded he repaint it. You can see the lime green peeking through in places it chipped and, sadly, I don't think anywhere under the hood was painted.
However, overall, it's a pretty damn good paint job, at least where it hasn't chipped to show hints of lime green.
1973 Ford F100 4x4
MrBonus
PostPost by: billwill » Mon Jan 04, 2021 8:13 pm
What is an ELECTRONIC fan as opposed to an ELECTRICAL fan ??
PostPost by: Andy8421 » Mon Jan 04, 2021 9:52 pm
billwill wrote:What is an ELECTRONIC fan as opposed to an ELECTRICAL fan ??
Modern electric fans for cars use brushless DC motors which have semiconductor switching electronics to control the current flow through the stator - rather like a 3 phase AC motor. This makes the motor smaller, more efficient and no brushes to wear out.
I am not sure this is what the OP meant, but the fans on modern cars are definitely electronic.
https://www.bosch-mobility-solutions.com/en/products-and-services/passenger-cars-and-light-commercial-vehicles/powertrain-systems/thermal-management-for-combustion-engines/ec-motor/
32 Standard 12
Various modern stuff
PostPost by: Seamus » Mon Jan 04, 2021 11:11 pm
Does that mean that mine is electrical...............
P1030035.JPG and
Seamus Doyle
1968 Elan S4 45/8357
1968 MGC Roadster
2002 MG TF160
2008 Lotus 2-Eleven
Seamus
PostPost by: pharriso » Mon Jan 04, 2021 11:43 pm
Seamus wrote:Does that mean that mine is electrical...............
Very!..... Nice original unit :-)
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: billwill » Tue Jan 05, 2021 2:38 am
Ah, not a bad idea I suppose. The fans in computers are also usually brushless DC motors.
Less maintenance, they last for years & then are usually 'fixed' by a drop of oil on the spindle.
Mind you I've not had any problem with my Kenlowe brushed DC motor on the cooling fan & its been on the car many many years.
Users browsing this forum: No registered users and 41 guests
cron
