Loss of power after pulling away at junction.
PostPost by: KevinM » Sat Dec 12, 2020 4:02 pm
Hi all,
I have just returned from a reasonably sporty drive around the winding bumpy back roads of Lincolnshire. The car was running well until I stopped at a junction and set off on a left turn. The engine just gently slowed with no throttle response. After a short while it picked up but was rather disconcerting. I tried the same manoeuvre on some empty road junctions with the same result. At one point the engine stopped completely after starting to pull away but ran ok when restarted. The car pulled well in a straight line or when moving up and down the gears. Any ideas? I have a standard Plus 2 breathing through Dellortos with electronic ignition fitted. The car was recommissioned by Spyder a couple of years ago after a few years in storage but has covered 2000 plus miles since then without issue.
1972 Elan Plus 2 130S
KevinM
First Gear
First Gear
PostPost by: h20hamelan » Sat Dec 12, 2020 4:33 pm
Fuel or spark
Any loose connections around the coil? Resistor?
Have you fitted electric fuel pump, and measured pressure?
Love your Mother
Earth
PostPost by: KevinM » Sat Dec 12, 2020 5:00 pm
h20hamelan wrote:Fuel or spark
Thanks, I will check tomorrow, I'm thinking fuel as it was a slow decrease rather than a sudden electrical type loss.
KevinM
First Gear
First Gear
PostPost by: StressCraxx » Sat Dec 12, 2020 5:35 pm
Thinking fuel is good. Check/replace your fuel filter, screens at the carbs if they have them on Dellortos, hose cracks or loose connections between the fuel pump and the tank. Debris at the fuel pickup in the tank.
StressCraxx
PostPost by: KevinM » Sat Dec 12, 2020 7:21 pm
StressCraxx wrote:Thinking fuel is good. Check/replace your fuel filter, screens at the carbs if they have them on Dellortos, hose cracks or loose connections between the fuel pump and the tank. Debris at the fuel pickup in the tank.
Many thanks will check those areas.
KevinM
First Gear
First Gear
PostPost by: 661 » Sat Dec 12, 2020 7:28 pm
Although fuel sounds the issue, I had a similar sounding problem with the 635CSi, it was the carbon contact in the distributor cap disintergrating.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
PostPost by: h20hamelan » Sat Dec 12, 2020 10:10 pm
maybe vacuum, carb to head?
Love your Mother
Earth
PostPost by: baileyman » Sun Dec 13, 2020 11:10 pm
h20hamelan wrote:maybe vacuum, carb to head?
Would be my first inquiry, too. John
baileyman
PostPost by: KevinM » Mon Dec 14, 2020 11:49 am
661 wrote:Although fuel sounds the issue, I had a similar sounding problem with the 635CSi, it was the carbon contact in the distributor cap disintergrating.
Thanks I'll look at that
KevinM
First Gear
First Gear
PostPost by: KevinM » Mon Dec 14, 2020 11:50 am
Ok thanks I'll check.
KevinM
First Gear
First Gear
