Cylinder head bent causing cam bearing wear
I am told by my engineer that the camshaft wear on my Europa twin cam is caused by a bent cylinder head. I believe that oversized cam bearings are not available. Is it a satisfactory solution to close the caps and line bore the tunnel, similar to the situation if the main bearings were misaligned?
Alan P.
Alan P.
- Panda
Hi Alan
Yes perfectly possible to line bore the cam tunnels like you can a block by machining a little off the caps and then re-boring taking an absolute minimum off the head.
If the head has not been re-machined flat in the bent state it may be possible to straighten the head to realign the cam bores.
Panda wrote:Thanks Rohan, I believe the head is unmolested. I do have a pretty decent torque plate which I will give to Garth at Repairs and Restorations in the hope of straightening it out. Any thoughts on that process?
cheers Alan P
some information here but lots of other stuff on the Web about it.
https://car-repairs-slacks-creek.com.au ... roblem.htm
https://www.enginebuildermag.com/2014/1 ... ightening/
another link with information on head straightening
Alan,
Has your egineer checked to see that the camshafts are straight?
- elanman999
