Crank shaft bearings
Have you any photos of the bearings to show?
If the bearings are new old stock and not newly manufactured this is a regular problem (not to say it's acceptable).
Some NOS bearings have some deterioration to the bearing face where they look discoloured - this is also an issue.
promotor - Fourth Gear
not the best for a blueprinted engine, but if in a pinch and eager to get going, I would rather use scotch brite, to smooth out any protruding rust bits that may prevent proper seating (avoiding to embed particles in the soft bearing material). Once in oil, corrosion is not likely to resume...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
street wrote:Outside face. 1st one has had some light 1000 gauge paper on it
Is it definitely not protective grease that has discoloured them?
The don't look like proper spec bearings for a Twincam - they look like standard duty Silicon Alloy. Original bearings were heavy duty lead/bronze with lead overlay - they have a dull look whereas those in your picture look shiny?
I'm sure plenty of people have fitted that type of bearing without issue but just thought I would mention it in case you aren't aware.
This is a bit off topic. When I last had any machining work done, the bearings that the machine shop supplied came from Tasmania, and I think the company was ACL. I know you are not in Tasmania, but that is much closer than the UK. Might be worth checking with ACL, before sending your scruffy set back to the UK.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
Looks like old stock that has been opened years ago and then not properly rewrapped and stored. New bearings these days come seal in shrink wrap and typically have a very thin layer of oil on them to protect inside the packaging.
I personally would return as unsuitable given the corrosion and buy new stock bearings which should be available locally in NZ through autoparts suppliers from ACL
Users browsing this forum: MACCA.GLM and 42 guests
