Genuine Big Valve?
Dear All,
I have found a nice Elan Sprint from 1971.
Everything seems in order.
However, I find the valve cover a bit unusual of a big valve.
Can you have a look of the picture and tell me if you don't think it's a pre big valve engine?
Thanks in advance for your support.
Br,
E
Br,
E
- suoita
The cylinder head is an early die cast head, so not an original BV head as fitted to Elan Sprint (and others). Of course may have been modified at anytime to include larger inlet vales as per BV.
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Or, it could have had the whole engine changed at some point.
Have you checked the engine number against the number on the V5 ? (Log Book).
Bear in mind that, whilst it doesn't make any difference to some people, most buyers like to see a "Matching Numbers" car, where the engine and chassis numbers are the same as when the car was new, and if they're not, should be priced accordingly.
I also notice that the paint colour s not original, (at least according to lists I see for a '71 car), being more like a British Racing Green. -( Google Lotus Elan Sprint paint colours for 1971) and I don't remember ever seeing a Sprint in BRG, or BRG / White.
The car needs a thorough check over, before buying. Chassis number, engine number, see if you can find anywhere on the shell that you can see the original paint colour, and report back.
Wouldn't want you to get bitten by someone who is presenting a car as a Sprint, which is actually a bitza !
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
Previous :-
- elans3
englishmaninwales wrote:The cylinder head is an early die cast head, so not an original BV head as fitted to Elan Sprint (and others). Of course may have been modified at anytime to include larger inlet vales as per BV.
Malcolm
Thanks for your help.
Can't it just be the valve cover?
- suoita
Dear E,
Contact me via my web site below with the VIN details and I shall tell you what the car should be.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
The new Dave Bean heads also have the half moons as they were made to look externally like the original early style heads ... except for the larger diameter inlet runners and i cant tell that from the photo
Heads and cam covers and engines get changed on Elans a lot so not really critical unless your looking for a concourse car. The early die cast heads don't make a good basis for a competition engine due to the smaller diameter inlet runners but are fine for a road car and can be easily tuned / modified to produce Sprint spec performance and more.
