Elan S4(Strombergs) starts for a minute then fades
I can look again but at one point I disconnected the fuel line and let it pump into a jar. Looked pretty efficient to me. I've plugged off the vacuum connection and also plugged up the hose to the light opening mechanism. I checked the firing order and that is correct.I was pretty careful to get the cams and sprocket wheels in the right position. I had replaced the valves too so maybe there is some issue there. It's really tough to define the issue. I'm now looking for a tow dolly so I can take it to someone who may have other ideas as I'm starting to run out of them myself.
- stebbs
You've tried another coil? Is there a ballast resistor fitted in series with the coil wiring?
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
stebbs wrote:I can look again but at one point I disconnected the fuel line and let it pump into a jar. Looked pretty efficient to me. I've plugged off the vacuum connection and also plugged up the hose to the light opening mechanism. I checked the firing order and that is correct.I was pretty careful to get the cams and sprocket wheels in the right position. I had replaced the valves too so maybe there is some issue there. It's really tough to define the issue. I'm now looking for a tow dolly so I can take it to someone who may have other ideas as I'm starting to run out of them myself.
they need to flow a certain amount, at a certain pressure. through specified diameter hose.
reductions, or expansions hinder this I would say.
Low flow or high flow. it needs to be close. watching it come out is not quantitative
same for spark, if its low. it may not be enough.
Both should be easy enough to do. Measure volume of fuel, over specified time. As for spark, can you purchase a spark plug gap tool. $20
Love your Mother
Earth
Love your Mother
Earth
i would start with the best coil money can buy, along with cap, rotor, & points. and set static timing over, and over again-to be sure
Love your Mother
Earth
Love your Mother
Earth
"Can’t tell you the exact revs as that’s another thing not working"
Some rev counters work by being part of the low tension circuit, the small wire on the distributer. If the rev counter isn't working properly it may be due to bad contacts/connections or a faulty wire. The coil connections may also be reversed. A bad low tension wire will cause the engine to ether show no sign of life or run badly. A bad condenser will also do the same thing. New ones aren't always any good so you sometimes replace good with bad when chasing a fault like this. A loose connection at the distributor or the coil can cause this sort of fault. Just remaking/re crimping the connector can cure the problem but the the loose connection sometimes not easily spotted.
Derek UK
Derek UK
- derek uk
derek uk wrote:"Can’t tell you the exact revs as that’s another thing not working"
Derek UK
Has anyone suggested checking the anti-theft switch (if the car still has one fitted) ? It's often responsible for poor starting and running issues and being hidden away is easily overlooked when checking for bad connections etc.
S4 DHC
S4 DHC
- oldelanman
Users browsing this forum: shynsy and 28 guests
