Recup Bottle Location (Plus 2)
Just got a new recup bottle and carrier from Moss to install in my newly acquired Plus 2 which did not come with one. Struggling to find the best location for this as the bottle is much bigger than I thought!
From pictures online, I have seen a mix of:
A) Near the radiator cap just behind the radiator
B) near the radiator cap just in front
C) at the lower end of the radiator close to the air intake
- fatal3rror
Can I suggest a different approach to this.
You appear to have a suitable space just there below the overflow tube and near the air intake hose.
Measure that space and then find a plastic bottle to fit.
I found a bottle 2 and1/2" square and 6" long which did the job nicely.
look for a suitable bottle in the hardware shop containing something you can use and decant it into something else. I appreciate that this is not `correct`, but you are not changing anything on the car.
Best of luck
Eric in Burnley
1967 S3SE DHC
Best of luck
Eric in Burnley
1967 S3SE DHC
- ericbushby
On my January 1970 +2S the bottle is mounted on the front face of the radiator bracket (fan side). However, the workshop manual says that the bottle has been repositioned on current production models (date at bottom of page 1170), with instructions for how to move the bottle to the rear face. So it looks like the position changed sometime during 1970...
draenog - Third Gear
Donels wrote:Collected loads of pictures for research on my rebuild and the attached seems to be pretty typical. Not my car I might add.
That's where it is in my early '70.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
draenog wrote:On my January 1970 +2S the bottle is mounted on the front face of the radiator bracket (fan side). However, the workshop manual says that the bottle has been repositioned on current production models (date at bottom of page 1170), with instructions for how to move the bottle to the rear face. So it looks like the position changed sometime during 1970...
I don't have the manual yet. Could you share the instructions?
- fatal3rror
The Veg wrote:Donels wrote:Collected loads of pictures for research on my rebuild and the attached seems to be pretty typical. Not my car I might add.
A close up on how the carrier is mounted would be really helpful is possible!
- fatal3rror
ericbushby wrote:Can I suggest a different approach to this.
Best of luck
Eric in Burnley
1967 S3SE DHC
Thanks Eric, seems like a sensible solution but trying to stick to the original if possible. Especially given I have forked out ££ for the carrier and the bottle already!
- fatal3rror
Yes, I realise that my suggestion is not very appropriate for you, but I am thinking that many other owners will read this, Mine looks the part and fits the space and cost nothing.
Eric in Burnley
Eric in Burnley
- ericbushby
My 130/5 had it in this location and I'm pretty sure it is the original place. The car was very original apart from the Spyder chassis.
JonB - Coveted Fifth Gear
fatal3rror wrote:draenog wrote:On my January 1970 +2S the bottle is mounted on the front face of the radiator bracket (fan side). However, the workshop manual says that the bottle has been repositioned on current production models (date at bottom of page 1170), with instructions for how to move the bottle to the rear face. So it looks like the position changed sometime during 1970...
draenog wrote:fatal3rror wrote:draenog wrote:On my January 1970 +2S the bottle is mounted on the front face of the radiator bracket (fan side). However, the workshop manual says that the bottle has been repositioned on current production models (date at bottom of page 1170), with instructions for how to move the bottle to the rear face. So it looks like the position changed sometime during 1970...
Perfect, thank you!
- fatal3rror
When I got my car it was in front of the radiator, but the car was running without the hose to the air cleaner. I repositioned it similar to the revised position in the manual, behind the radiator, but as my car has a full width radiator I made my own mounting bracket that secured to the right side chassis mounting bolt that secures to the suspension tower.
- Bigbaldybloke
fatal3rror wrote:The Veg wrote:Donels wrote:Collected loads of pictures for research on my rebuild and the attached seems to be pretty typical. Not my car I might add.
It's riveted to the rad-mount.
2012 BMW R1200GS
2012 BMW R1200GS
