Oil Pickup Tube - Screw in
PostPost by: Tmac897 » Sun Jul 12, 2020 8:23 pm
I have a ropeseal engine, and so I have the older, screw-in oil pickup tube with the integrated screen. The screen on mine was shot, so I've tried repairing it by prying up the edges of the pickup, and re-inserting SS screen. I don't trust the repair, as there was actually sort of a relief fitting in the middle of the original screen that I can't really duplicate, and, since I'm cutting a round piece out of essentially square material, there are places where the ends are a little ragged and I'm wary of those sections holding properly.
Anyone ever performed this operation? Is there a conversion from the newer press-in style? Compatibility with parts from other Ford engines?
Any information would be appreciated.
Tony
Tony
1967 Elan S3 SE
Northeast US
Tmac897
PostPost by: 2cams70 » Mon Jul 13, 2020 3:21 am
Lotus Marques here in Australia have made a replacement. You can also get it with the screw type fitting for the earlier blocks. It's the same part as standard Mk1 Cortina though so shouldn't be too hard to find secondhand.
https://lotusmarques.com/parts/news/148 ... r-assembly
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: rgh0 » Mon Jul 13, 2020 4:42 am
If making you own screen you may want to roll the edge and braze it to stop it fraying.
If trying to buy the screw in pick up second hand be aware that there are two types. One that used a steel sealing ring in the block and had a shorter nut and one that did not use a sealing ring and had a longer nut. Make sure you get and use the sealing ring if buying one with the shorter nut.
The threaded mounting hole in the block as the same for both types of pickup.
PostPost by: promotor » Mon Jul 13, 2020 9:20 am
Tmac897 wrote:Hi,
Tony
There are two different screens on the rope-seal type pick-up pipes (plus the basket type on the lip-seal type pick-up) - which one have you got? I've got both if you're looking for a replacement. I'm in the UK though.
promotor
PostPost by: Tmac897 » Mon Jul 13, 2020 12:06 pm
Not sure how to identify, so here are some pics:
Tony
1967 Elan S3 SE
Northeast US
Tmac897
PostPost by: Tmac897 » Mon Jul 13, 2020 1:27 pm
rgh0 wrote:If making you own screen you may want to roll the edge and braze it to stop it fraying.
Thanks, Rohan. I might give the repair one more try.
Tony
1967 Elan S3 SE
Northeast US
Tmac897
PostPost by: Tmac897 » Fri Jul 24, 2020 3:45 pm
Following Rohan’s suggestion, I had the screen on the pickup brazed. Looks like problem solved there.
In addition, there was quite a bit of rust damage where the pipe joined the pickup “bowl.” The spring was doing nothing, and the gap between the flared end of the pipe and the bowl rendered the bowl useless for oil scavenging purposes. So I had the pipe and bowl brazed as well.
I’ve included some pics. Anyone see any obvious problems with this?
Tony
59890EAC-CC1D-4F2F-B2F5-50194E255A98.jpeg and
7B64E436-1579-43F4-93B2-B111660B0FDE.jpeg and
Tony
1967 Elan S3 SE
Northeast US
Tmac897
Users browsing this forum: No registered users and 65 guests
