Transverse exhaust
as far as I know.. they are a rubber strap with a hole each end. the hole is reinforced with a metal plate.
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
can measure tomorrow. both are the same and hang from bolts facing the battery. I suggest a decent penny washer or other strengthening. PO had put a fairly hefty bit of shelving bracketry along the top, inside the boot... looked like it had all come off in the past.
- wotsisname
That’s very helpful, here is what SJ supplied me with, the bracket clearly wrong and the strap also I think as it only measures 8 cm which has got to be shorter than the one shown in your photo.
When I offered the system up to the car yesterday (so SS manifold pipe and box) it seemed to me that the long pipe was a bit too long as the box was butting up against the recess in the body. From your photo it looks like you may have fitted a SS system, did you have any issues with fit?
- NYK
Hi, been a while since I fitted it.. My project is one that I started and then it stopped for some years.
the parts you have look like those I have seen in the parts list for the straight through system. If you haven't already, I'd recommend looking at the page for the exhaust.. can be found in the wiki I believe.
from memory... I bought the exhaust from Christopher Neil I think.... I think I had to cut a section from the long pipe (3-4" springs to mind... there is a chance I may still have the offcut) .. I think the factory drawings were incorrect and they were all a bit long back in the 90s, Mine is also all SS. I seem to recall I found a hole at one of the welds of the manifold and had a friend weld it up properly. I can take a photo of how it sits in the recess.. it can be made to fit quite well, you have to do a bit of rotating of the main pipe & the box to get it to all sit close to the chassis and the tailpipe pointing in the right direction.
- wotsisname
Yes, I found the parts list and it is quite clear that the above bracket is from the straight through box. Annoyingly SJ insisted it was correct, I told him he was wrong and should take a look at the parts list. I find SJ generally unhelpful and certainly compared to Paul Matty who I subsequently spoke to who were happy to spend 5 minutes or so trying to find what I needed. SJ no longer on my preferred supplier list! Unfortunately PM did not have the part so I have ended up buying a generic strap off eBay.
I think I will wait for some cooler weather before I try fitting it, not much fun lying under the car this weather.
- NYK
Sounds like you were unlucky with who was in, at SJ. only issue I had was sorted out pretty quickly.. Their website looks to list the part...
X050S0094Z silencer strap for transverse silencer.. looks about right
Paul Matty also good and a few others as well..
I use Susan Miller a bit, can be tricky to get hold of her but usually works out. She has initiated remanufacturing of quite a lot of bits over the years.. so can have the unusual stuff.
will get my camera and tape measure ...
- wotsisname
OK, this is now getting really confusing.
Firstly the guy at SJ is really annoying since he clearly was totally unaware they sold the correct strap.
Secondly, I don’t understand Craven’s comment. If you look at the parts manual it shows two straps and no brackets. I don’t understand why the two straps would attach in different ways. Craven can you explain what you mean?
- NYK
mine is as shown in the parts list. 2 straps to the front of the silencer. inboard strap is 8cn long, hole centres 5cm. 3.8cm wide, metal reinforced at each hole.
the outer one looks like I made it. 11cm long, hole centres 8.5cm.. as best I can measure.
- wotsisname
Mine is like this. straps are held by bolts facing the battery. the shield is held in by bolts on top of the body recess. I dont for sure know that this is the correct way to fit all of this, but see no other method in the parts list /WSM. I fitted mine with nuts upward, I think a domed screw ,with nuts down, would give a better look and allow a covering on the boot floor to fit.
The owner manual shows a covering and leather tool straps appear to be fitted to the hanger bolts.
Adrian
- wotsisname
As said, this how I did mine and seems to match the parts list and how the car was when it was about 20yrs old.
- wotsisname
Adrian
Adrian, at the risk of opening another can of worms, did you buy the heat shield recently and if so from whom?
- NYK
